Hmmm. HeadShop seems to have disappeared from my Edit menu. Hadn't made any changes yet. Have un/re-installed w/o any luck. Files are where the ReadMe shows they should be. Sent Abalone LLC a separate message.
Still a mystery why it disappeared but Thanks to Laslo for getting me going via Skype today. Didn't get a chance to tell him how much he looks like my Dad in earlier years & took me back for a moment.
That's funny. Maybe he was my brother from another mother:-) Glad that we solved the issue in 10 minutes via Skype
The universe is a funny place at times, that's for sure. You decide:
Anyway, having a blast with the tool now. Just have to get the workflow down so I co-ordinate all the assets now & not overwrite with a new HeadShop project.
Tried earlier that and had an odd error; a bunch, but not all of the geom disappeared. Didn't happen the next time just sticking to the default fs so not sure what I did different. I'll explore that more though. Got two projects working correctly for now doing some manual save & renames.
BTW, I still can't get that one photo (girl in the white scarf) to import. Tried tweeks to levels & cropping, but just no luck. You mention you simply lightened. Any other ideas?
I bought Headshop 11 today.
So far I have two issues.
First Genesis 8 eyelashes problem mentioned before.
Second - when I select File->New, the window pops under the main Headshop window and I have to force close thru Windows Manager
I've sent an email to [email protected] cause I'm not getting anywhere. I have managed just one successful render with a photo face, but it's hit n miss whether the eye holes line up on both gen 3 and 8 most of the time. This is not a cheap add on. I have downloaded the 'fix' as checked further up the thread, and am awaiting further help via email. If not, I will ask for a refund. This is a fabulous idea in theory, it's got too many bugs for it to work successfully at this moment, unless I'm a complete numpty, and missing something.
OK, SOOOO, I've Installed HeadShop 11 multiple times, reinstalled (Repeat-Reapeat-Repeat-Reapeat-Repeat-Reapeat-etc...) - and yet, I cannot get a freaking mesh to generate! I have copied all installed files to the following directory locations (JUST INCASE!):
C:\Program Files\DAZ 3D\DAZStudio4 Public Build\plugins
C:\Program Files\DAZ 3D\DAZStudio4 Public Build\HeadShop plugin
Everything works until I engage the "Apply" button. Then I keep getting the messages in the attached pics & then the Genesis 8 model looses the head & torso geometry.
What in the world am I missing here?!!! I even followed a General Install video on YouTube. But I cannot find a Video, PDF, or Pic file anywhere to show exactly where each file should be located.
It appears that I have more or less the same problem as user "d32un3d" just above this post.
I bought HeadShop 11 today and have had problems installing the software.
The files appear to be in the right places, but since I have a custom Daz Studio installation, HeadShop is not finding the correct path to the standard Daz characters.
On top of this issue, there might be some extra issues as a result of the Daz Connect/Cloud system, just thought I'd mention that.
Error message: "Daz model not found".
I would suggest for the developer to add a text-box where the user can see either a working path to the necessary folders/models/resources,
or an input field and/or browse functionality to manually set the correct path. This would be useful in cases where the user have a custom installation.
Apart from that, I haven't found anything regarding HeadShop 11 in Daz Studio, there is no link from the "Edit" menu or other reference to HeadShop.
There is no plug-in showing up in the plug-in list in Daz Studio either.
As I said, the HeadShop files appear to be in the correct locations as are laid out in the documentation.
I have only started HeadShop from the .exe file, since there is no menu available in Daz Studio.
I actually figured out how to get the plugin to work within DAZ, but still discovered exact same issue of "DAZ Model not find"...& I have since confirmed that all files are in the correct locations (data path)... I returned Abelone's FaceGen 2 due to horribly inaccurate results. Looks like I'm gonna have to do the same with HeadShopp 11 - & prolly just avoid Abelobne products in the future. Sigh...
I've installed HeadShop 11 for the general release version of DS 4.12 and it works, etc., but it doesn't show up in 4.12 Beta. Not a big deal but would that have to be a separate install or is some other step needed?
Neck issue fix involves two small files that needs to be replaced inside the "HeadShop plugin" folder. No need to reinstall anything:-)
Give us a couple of days - still testing.
Lightening didn't do it on this end. Looking forward to the update though.
Will the fix work with HeadShop OneClick2 also? Is there and expected date?
Yes and yes. Download at https://www.dropbox.com/s/ccpj5x9cza5edix/twofiles.zip?dl=0
Unzip and replace same name files in the HeadShop plugin folder.
Glad I checked back.
M.
He does look like me:-)
Not overwriting is easy: you have to name the project something other than fs (see picture).
greetings!
one more thing regarding Eyelashes - seems that DAZ doesn't load Headshop morphs to eyelashes...
HeadShop Tech Support: [email protected]
I can't install HeadShop OneClick2, because it wants a product key from me, and I have no idea where to locate that.
SInce noobody else seems to have had that issue, I am thinking I may be missing something obvious.
Does anyone have a helpful hint to offer?
Check the Serial Numbers tab on your Account page here.
______________________________________________
C:\Program Files\DAZ 3D\DAZStudio4\plugins
C:\Program Files\DAZ 3D\DAZStudio4\HeadShop plugin
Please HELP!
Please read the README file (enclosed here and also in your zip file).
Also watch install video eher:
Lastly, the manual also gives you installation instructions https://printahead.net/wp-content/uploads/2018/09/HeadShop11manual.pdf
Quick question:
DAZ Studio beta has different file names and may not work with HeadShop. Better wait for release version.
That's fine. Just wanted to confirm.
