A Technique for Creating Realistic Oceans and Seas
2»
  • FractalDimensiaFractalDimensia Posts: 0
    0oseven said:
    Thanks
    I tried that and didn't seem to work but maybe I had some incorrect setting = will try again. thanks again.
    I have been too busy to attempt animation (yet). My initial thought was to adjust the terrain settings, but TBH, I don't even know if those are animate-able. If you get something to work, please post it here!
    FD
    You can animate the terrain using the wave deformer. The phase should be at 0% at the start of the animation and 100% at the end.
    400 x 300 - 573K
    247 x 517 - 24K
    253 x 683 - 33K
    Thanks, EP, for sharing that! Nicely done too!
    FD
    Now that I've started down this track and thinking about what it would take to create an animation of a boat rocking on rough seas, the next question is:
    How do you find the perpendicular (angle) of a terrain surface at a specific point?
    I know that when you populate trees (e.g.) on a terrain, there is an option that places trees perpendicular to the surface, but I don't know of a way to relate one object (e.g., a boat) to the terrain in this fashion.
    I'll have to experiment with replicating 1 copy of a boat onto the ocean terrain's surface, and see if it creates the right effect.
    I can't picture how to use physics animation, but that might also be an option.
    FD
  • Philemo_CarraraPhilemo_Carrara Posts: 1,175
    Sparrowhawk has a 'follow terrain" plugin. I think it could help.
  • McGuiverMcGuiver Posts: 219
    I did a bobber hitting the water a few years ago & just keyframed the bobber movement.
    animation is at shoestring shaders site. > http://www.des-web.net/html/samples.html
    If you are using a replicated terrain, getting your boat movement will require alot of area renders, as the follow terrain modifier can't have the boat follow a replicated terrain. The other option would be just using a terrain without replication, as I did with the bobber.
    Philemo and McGuiver, good inputs! I've heard of Sparrowhawk's plug-ins, so I will definitely look into that.
    Nice job on the bobber, McG. I'll have to consider how to create a terrain large enough not to need a replicator then...
    Thanks!
    FD
  • RoygeeRoygee Posts: 2,247
    edited September 2013
    A trick 3dage gave me some time ago using the ocean primitive - should work equally well on an animated terrain.
    Replicate, hide the original then place a boat - you will have to mess about with the boat's pivot point to get it just right - and it will bob about nicely as the ocean (terrain?) moves. Just trying to remember - was it a replica of the boat, was it parented to the ocean?
    My "real" PC gave up the ghost last week and I'm waiting for a custom-built replacement, so can't experiment with this at the moment. No point in trying anything CG on this toy laptop:)
    Post edited by Roygee on
  • VarselVarsel Posts: 574
    Not exactly an ocean..... but its water.
    I have been experimenting, trying to create a waterfall.
    The water at the top is just a simple mesh. It could have been even simpler, but I made a copy of the terrain, and re-sculpted and removed unnecessary parts.
    The waterfall is a base mesh, in the shape of the fall. No details, since it will be hidden.
    On this mesh I replicated the waterdrops.
    I just couldn't get the water to look right, until I tried to put a little bit of glow in the shader. 2 % was just right..
    I did also use caustics when I rendered.
    1145 x 600 - 278K
    600 x 800 - 506K
    600 x 800 - 437K
    That's gorgeous!
    TUTORIAL! TUTORIAL! :D
  • DartanbeckDartanbeck Posts: 21,959
    Varsel, that looks absolutely stunning!
  • ed3Ded3D Posts: 2,489
    ~  interesting  subject  ~
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,170
    Ed have you seen EvilProducer's freebie?
    http://carraracafe.com/tag/ocean/
    ~  yeah ,  pretty much  ~  thanx  -
  • mindsongmindsong Posts: 1,725
    saw the carrara cafe link a while back (tnx wendy), but missed this one.
    thanks for bumping it @ed3D
    --ms
    --ms
    +1  Fractal Dimensia fricken ROCKS! This is a great article!
    edited October 2020
    --ms
    --ms
    ~   you`re welcome  ~
    Post edited by ed3D on
  • DiomedeDiomede Posts: 15,391
    So much can be accomplished with (1) terrain primitive, (2) replicator on grid and seamless settings, and (3) water shader that uses the slope and elevation functions to drive a foam shader mixer.  In particular, #3 can make animating ocean waves spectacular.
    @Varsel - very impressive waterfall and clever use of the glow channel.  Remember it from a great challenge entry.
    I love that waterfall! I love all of Varsel's work, actually! :)
