2 questions about Carrara 8.5 and DS4.6 compatibility.
AntaraAntara Posts: 444
Question1: Did I hallucinate, or was it mentioned somewhere that Carrara 8.5 Pro should be able to handle micro-displacement similarly to the way DAZ Studio does? Should we be able to use the displacement maps in a similar way to DS? If so, is there a special way to go about it? Special settings? Special imports?
Question2: I thought we should be able to save a scene in DS4.6 and then open the *.duf file in Carrara. Is that correct?
If it is, then I just found a bug, in which the *.duf opening scrambles up a bunch of objects. Should I be saving it differently somehow? or opening it differently (the objects get deformed both when I open the *.duf file and when I first create a new file in Carrara and then try to import the *.duf file)
Attached are images from DS and Carrara (in Carrara, look at the Kids4 hands and the clothing items on V4: they are way off and the distance is compensated by stretching some polygons into "noodles").
    noodles? you call those 'noodles' ? :)
    sorry I am not smart enough to figutre out daz studio ;0
    but it looks like your limits have been turnedd off on the bottom image.
    if you move a bone a very slight amount do they snap back into place (ie are they 'denoodled"?)
    sometimes happens for me in cararra 8,1 - ie geting the limits back.
  • AntaraAntara Posts: 444
    Unfortunately, it doesn't snap back. It continues moving in this messed up state :(
  • araneldonaraneldon Posts: 712
    I didn't notice any significant improvements to displacement in the public beta, and there isn't any mention of changes since then.
  • Philemo_CarraraPhilemo_Carrara Posts: 1,175
    When I look in Carrara tech spec, it says in the Vertex modeling section : Displacement & Microdisplacement Mapping (pro only)
    Now, that being said, I haven't found yet how to use Microdisplacement :-(
    Since when has that been there? If they've improved displacement since the 8.5 beta, this update might be worth buying despite the issues with Genesis/DSON...
    I don't know, just found it today.
    Oh yes, it would :-)
    After a quick google search, it appears it's been in the specs since Carrara 5 :-(
    let's forget it...
  • DartanbeckDartanbeck Posts: 22,154
    One of the "Known Issues" (listed in the Carrara 8.5 ReadMe) is that more than one pre-Genesis figure in a DUF doesn't work properly. Something like that, anyways.
