Sickleyield's dForce Roman Clothing Pack color cloth problem
Did a bit of searching on the forum without success so here I am.
I have 100% problems getting the colors on to the various clothes. I may be seeing the forest thus missing the trees so be nice. wink
I have yet successfully colored any Roman toga and the like.
Hmm? I think I've made the point and repeated myself. *shrug*
Rycharde
  • Have you rendered, or used the iray preview mode, or are you just going by the texture shaded mode? As I recall some of the options don't show without rendering.
  • Thought that was the case, colors appear during render but... Hmm? I was putzing around with the colors and such, I may have reset the colors to white before rendering having done the render mode once. I'll try again. Be back with the results.
  • No joy. Was working under iRay preview. Tried various attempts but no go. Going to uninstal/reinstall see if some files were corrupted.
    For the colour-fill, the materials are SHADERS (The folder is actually called 'Color shader' but may be obscured), and need to be applied with the Shader tab open, and the cloth surface/s selected. The borders can be applied either way. I hope that helps!
  • Thanx. laugh
    yes
