Sickleyield's dForce Roman Clothing Pack color cloth problem
RychardesRealm
Did a bit of searching on the forum without success so here I am.
I have 100% problems getting the colors on to the various clothes. I may be seeing the forest thus missing the trees so be nice.
I have yet successfully colored any Roman toga and the like.
Hmm? I think I've made the point and repeated myself. *shrug*
Rycharde
Have you rendered, or used the iray preview mode, or are you just going by the texture shaded mode? As I recall some of the options don't show without rendering.
Thought that was the case, colors appear during render but... Hmm? I was putzing around with the colors and such, I may have reset the colors to white before rendering having done the render mode once. I'll try again. Be back with the results.
No joy. Was working under iRay preview. Tried various attempts but no go. Going to uninstal/reinstall see if some files were corrupted.
For the colour-fill, the materials are SHADERS (The folder is actually called 'Color shader' but may be obscured), and need to be applied with the Shader tab open, and the cloth surface/s selected. The borders can be applied either way. I hope that helps!
Thanx.
