is it possible to bulk save renders in DS?
daveso
in The Commons
I usually hit render quyite a few times in doing a final scene... or change things up and render..resulting in 10 or more images that need to be saved.
Is there a way to save all of them at once, maybe just calling them the date followed by a sequence number or something?
Have you seen this? https://www.daz3d.com/super-save If I'm understanding you correctly, I think it does what you just said. Love this product!
thanks.. I was looking for something to save renders, not the scene.
You do know that DS doesn't free up memory from previous renders if you leave the image window open? So having all those images sitting around will eventually cause your renders to go into cpu mode. You should save or discard renders when you finish them not leave them around.
If you are looking for a batch render option, I haven't used it but there is this:
https://www.daz3d.com/batch-render-for-daz-studio-4-and-rib
i dont even have a gpu .... so I'm always rendering CPU mode.... so far not really any problems. I had 20+ open one day.
that looks decent. wonder if it works for iray
Yup it does! You need to enable "use saved scene settings" or whatever it was called
It would be so cool to have something like "Adobe Media Encoder"!!!
I could go out for some hours, and then find all my renders done, instead of suffering while I wait for them one by one, with an unusable PC :'(
Another way would be to use back-up software to 'watch' the temp folder.
I use File Hamster to watch for the r.png file specifically and that file gets backed up (with a date/time stamp) every time a change is detected.
Don't think you can do it automatically after you have created a new render, as DS deletes the file containing the previous render as soon as you create a new one. After that the only option seems to be to save manually from the open render window. You should grab the file from each render as soon as it's been created, and before you do a new render. I'll suggest doing like prixat said, that works.
i dont want to save the file, the figures, models, and stuff that is created, just the resulting renders. the images
Yes, and you can do that with that app, assuming that it can copy the render to another folder. Just make it copy the r.png in the render/temp folder to another folder each time a new one is created.
Correction: the full folder path is C:\Users\[user]\AppData\Roaming\DAZ 3D\Studio4\temp\render
ok..thanks..downloaded trial version.
it works really well.. thanks
I thought it was free. I wrote an app that does something similar to make up for a bug in the batch renderer, but I think that bug has been fixed now. I can easily modify it to do the same.
If you are using 3delight you can render RIB in batch files you just have to set your folder locations .just beware RIB batch files tend to create huge data sizes in folder and its not fast rendering to RIB but its great for creating animations with the PNG that come out
3 days ? yikes ... i'm impatient after 30 minutes.
yes its awful the time it takes I only tried it once for myself and I forgot to mention 3DELIGHT is a renderman base render engine that is described in The RenderMan Interface Bytestream Protocol Library. and you really would bennifit from the plugin for Renderman for speeding up batching theRIB files or you can do it the hard way and script your own batch files like i did which takes some time but you can find some good cheat in the rmd library http://hradec.com/ebooks/CGI/RPS_13.5/prman_technical_rendering/users_guide/options.html#rib_format
heres a link that explains the whole thing and how to set it up where to down the plugins (yes they have 90 day trial versions) http://hradec.com/ebooks/CGI/RPS_13.5/prman_technical_rendering/users_guide/rendering.html
and if you have the money you can actually rent or buy render time on renderman server or outright https://renderman.pixar.com/product
Oh or you might try using a cloud rendr service google has a pretty good one according to the reviews i haven't tried it yet myself though its still cost money https://www.zyncrender.com/
THANKS.. although i am pretty much broke... i have a small amount i spend here, but thats getting less all the time.
Yeah ..I'm pretty much using iray.
Yes I am with you I'll try to work within what I have now in daz,carrara & and poser11
