Viewport :-(
McRenArt
in The Commons
Hi ,
I can't find a way to get my viewport to change resolution ... enclosing a screenshot to make it clear :-)
happy new 2019 ! :)
Ren
It is in render settings, general, dimensions.
Thank you ,this is where it used to be ... but I'm using version 4.10 pro ... and when I click render settings I get this ( attached file )
I might just be dumb, but I can't finf it .. please bear with me :-)
There's a row of tabs at the top, just above All Files - you need to be in the Editor tab (where you can edit individuals ettings), rather than the Presets tab (for aplying a pre-defined set of values) as now.
Thank you :-) :-) (y)
Found it ^_^ happy 2019
You're in the wrong tab; try Editor tab
Found it :-) Thank you
