Viewport :-(
Hi ,
I can't find a way to get my viewport to change resolution ... enclosing a screenshot to make it clear :-)
happy new 2019 ! :)
Ren
  • 3WC3WC Posts: 1,164
    It is in render settings, general, dimensions.
  • Thank you ,this is where it used to be ...  but I'm using version 4.10 pro ... and when I click render settings I get this ( attached file )
    I might just be dumb, but I can't finf it  .. please bear with me :-)
    462 x 465 - 141K
  • There's a row of tabs at the top, just above All Files - you need to be in the Editor tab (where you can edit individuals ettings), rather than the Presets tab (for aplying a pre-defined set of values) as now.
    There are 3 tabs under the render settings. Right now you have it under 'presets'. Switch to the 'editor' tab. Also, the 3rd tab 'advanced' lets you select which hardware run the render, along with the optix on or off.
  • Thank you :-) :-) (y)
    Found it ^_^  happy 2019
  • nicsttnicstt Posts: 11,715
    You're in the wrong tab; try Editor tab
    Found it :-) Thank you
