Your own face on the M3, or the M4 characters
what is the best method or best program to use to put your own face on one of the Daz characters
Morphs will be hard. V3 had a set called something like "Face Sculpting" that was a LOT of fine detail morphs. I don't know if it ever crossed over to M3 or V4.
MATs could be a little easier. Various modelling packages let you apply a photo directly to the model and create the texture map for you. I think Blacksmith 3D and zbrush both have this feature.
Are you going to animate it? If I had to do this for a still image, I would learn how the people do the celebrity fakes in photoshop and do it that way.
If you're running Windows then I hear Faceshop does a pretty decent job http://www.daz3d.com/faceshop-8-win. Can find it here in the store http://www.daz3d.com/faceshop-8-win
I don't really know much about this sort of thing, but it's a start.
pwlecek raises an interesting idea. I know with Blender you can apply images to geometry, but it is a quick and dirty trick. Even with Faceshop you will need to fix up the back of the head.
Thanks, I tried using an earlier version of Face Shop but didn't like the results, I really couldn't get the head to match up with the face, guess I have to learn how.
You could take a re-named copy of the M4 face texture into photoshop (or similar) and add your face in it's place. It would take a bit of work to get everything stretched and toned just right, but it is possible. shadows can be problematic using this method.
I suggest also to keep an eye on the developments with the Kinect sensor.
On YouTube, as a search term, type e.g. "face recognition+kinect".
or: "brekel+kinect".
thanks guys, I just by chance do have a kinect sensor, I'll try it with that and I'll also try photoshop!!
