Carrara Rain Storm - Free to Carrara Users - beta released (updated)
HeadwaxHeadwax Posts: 10,470
edited December 2018 in Carrara Discussion
Hi, been working on this for a while. Just a simple rain storm with splashes and puddles. Would be ideal to use with Diomede's free trees.
EDIT: Please find the beta files attached to this post. To use rename the files from txt files to car files.
EDIT 2: Have uploaded new Storm Creek with Shaders removed (after  feedback)  - apologies
Edit 3: The Rain file by itself is the 2.97 mb file (hopefully the one after the pdf)
Feel free to fine tune them or offer suggestions etc. Commercial renders fine of course. Any problems please let me know.
I didn't include lightening etc. Maybe later ;)
Instructions for use in the next post or in the PDF attached to this post.
Image may contain: outdoor
Image may contain: plant, tree, bridge, outdoor and nature
Image may contain: bridge, plant, tree, outdoor and nature
Image may contain: sky, outdoor and nature
Image may contain: plant, tree, outdoor, nature and water
Image may contain: sky and outdoor
No automatic alt text available.
Image may contain: outdoor, water and nature
Image may contain: 2 people, people standing, child and outdoor
Post edited by Headwax on
«13
  • HeadwaxHeadwax Posts: 10,470
    INSTRUCTIONS;
    Download scenes from the first post and change the file types from txt to car.
    The following use the sample scene (note: scene already has rain in it - just delete the part that says RainGroupStormBeta in the isntances list on the right  it if you want to load it up yourself)
    STEP 1) Set up your scene first with cameras etc
    STEP 2) Drag or import The Carrara Rain file - if dragging it drop it on Scene so it doesnt become a child of anything yet
    Then select your Scene's Camera 1, hold down ctrl and select the Rain Camera. Ctrl K will bring up the alignment window. Align on all three axxii.
    SETP 3) Check your camera 1's rotation and make the Rain Camera's rotation the same
    SETP 4) Drag the rain group to make it a child of your Camera 1
    STEP 5)  Fine tune the rain by selection the Rain Plane and using the morphs
    STEP 6) Furher fine tune the rain by selecting Rain 1 and using the morphs
    Image may contain: text
    STEP 7) For more rain, make this visable
    STEP 8) To make the rain brighter select the lights in each rain group and make them brighter.
    STEP 9) One everything is setup then you can move the Camera 1 around and the rain will follow.
    THE SPLASHES AND PUDDLES FILE
    The splashes and puddles are surface replicated on 'ground'
    Double click the Surface Replicator and in the room that opens up, change 'ground' to the object you want the splashes etc replicated on.
    The splashes have morphs to make them bigger.
    You can make them brighter by tuinng the Splashes and Puddles Light.
    To make the ground they sit on appear to be wet, dont forget to add reflection in its shader.
    NB: the puddles look a bit odinary.
    2142 x 715 - 6M
  • SileneUKSileneUK Posts: 1,977
    Hi Andrew... WOW... thank you. Looking forward to it... I downloaded Diomede's trees already to put away till the New Year. Very tight on time right now, but you and Dio are making for a very Happy Christmas as not much left in the budget for models at the moment.
    heartyeskiss  Silene
  • VyusurVyusur Posts: 2,235
    Wow! It's so impressive!
  • wet wet wet
    good one
  • PhilWPhilW Posts: 5,162
    Looks great - I assume it isn't animated?
  • DiomedeDiomede Posts: 15,410
    Andrew, this rain scene is a great idea.  Wonderful work.  Thank you in advance.
    As a side note, during various sales, I picked up a Bryce inclement weather product by the masterful David Brinnen and Horo with the intentions of trying to get them to work in Carrara, or at least transfer what could be transferred, but that project is still buried on my to do list.
    https://www.daz3d.com/bryce-7-1-pro-environments-inclement-weather.
    I'd love to try to combine some of the Bryce content (HDRI,...) with your rain scene.  Can't share it, of couse.
  • Awesome. looking forward to it!
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,639
     well I actually did animated rain over old London once
    with splashes
    using Octane
    trying to find video, maybe I deleted it
  • GreymomGreymom Posts: 1,146
    Wow - this looks great!
  • Incredibly useful!  Thanks, looking forward to your release.
  • de3ande3an Posts: 915
    This looks great! I'm anxious to see how you did this.
  • StezzaStezza Posts: 8,932
    This looks cool
    we’ll be able to break the 3D drought with this wet one ... get your brollies out yes
    Thanks so much everyone, lovely to have such positive feedback!
    I've uploaded the beta files in the first post. They are free to use for carrara users - feel free to fine tune them.
    PhilW - the rain itself is easly animatable using the supplied morphs - the splashes I havent had enough time to look at how to animate them.
    Maybe a noise distribution shader in the surface replicator that itself is animated? Not sure as I havent had a chance to experiment with that.
    Please let me know if you have any problems, suggestions or questions.
    thanks again
    regards from oz :)
    FYI - the first file the storm creek is looking for a few graphic files that isn't there...
    the other two loaded ok... having a look at it now.. thanks for them yes
  • Bunyip02Bunyip02 Posts: 9,292
    Many thanks, have downloaded but will have a play later on !!!
  • mindsongmindsong Posts: 1,754
    thanks a ton!
    like others, playing with it may have to wait a bit, but i've already got 3 projects in mind that might benefit.
    not enough hours in a minute, I say!
    --ms
  • Steve KSteve K Posts: 3,489
    Very nice, many thanks ... looks like a lot of work donated to the group.  yes
    Thanks Stezza, I have taken out the unwanted shaders and stored the remaining one internally and reuploaded the file - thnaks for that!
    SteveK, Bunyip02 and Mindsong , thanks for playing :)
    Another FYI:
    The new "stormcreekwithshaders" file crashes my Carrara 8.5.1.19 Pro app (Mac version) as it begins to load. The original file "CarraraStormCreek" loaded OK, but prompted for 3 or 4 shaders. The other two files load OK.
    I can't load the StomCreek file.  Windows 10.
    Unfortunately, the only message that I get is "An error occurred while executing Open...."  Not very helpful for diagnosing the problem.  sad
    The rain file and the splashes file both open.  They look great.  yesyes
    Gah, thanks Ted et de3an.
    I'll take that file down and check it when I get back on my computer!
    I opened the new version 2 file no problems... the first version did crash on drag and drop from the tab but loaded ok on Open File..
    No probs here with any of them since you uploaded the new V2..
    Plane in Rain
    900 x 600 - 463K
    Post edited by Stezza on
    Classic Stezza :) Love that logo on the plane !
    Thanks for the feedback on the file - not sure what is going on there....
    Andrew,
    You took down "RainGroupStormBeta" instead of "stormcreekwithshaders" (the one that was crashing).
    I took the rain and rain drops out to use them in my own scenes... works well..
    800 x 600 - 818K
    de3an said:
    Andrew,
    ah thanks, will fix, apologies!!
    Stezza, that image is terrific. The raindrop splashes on the wingtips are just right.
    Next time . . . . use waterproof glue! laugh
    Love the render!
    There's interesting hair shader that makes a primitive plant (see the dark green folage in image) that comes in the Storm Creek scene
    I've updated the Storm Creek File - reposted it in the first post - should work now as I've taken the shaders out.
    1598 x 1094 - 7M
    Stezza & Headwax - looking great !!!
    Time tomorrow to join in the fun.
