Platinum club coupons start a day early?
in The Commons
Normally I use the coupons early enough in the month that I do not notice this but this is the second time I've waited until the last day, due to life, and found out that my coupon from the month before had already expired. I'm easter standard time and it is 9pm here on nov 30th, that means something like 6pm mountain standard time. So I'm well within the time that this should still be the prior month. Is this normal?
Yes, that is how it works. If you haven't used the November coupon/s, you can still use them today. Then turn around and use the December ones if you want.
Ok thanks. I could not figure it out.
