g8f measure metrics uneditable (updated 14 nov 2018)
Ikyoto
I can add MM, open the panel, but cannot edit values. This time I'm honestly stumped.
Post edited by Ikyoto on
Are you in the Configuration tab, and do you click the Select a Node button, select (presumably) the figure, and then click the Seelct a Property button?
Yup, but when I go to the "measurement" it's locked and even unlocking it, the value is uneditable.
Worked for me - I assigned Shin Length, from the Genesis 8 fenale version of Shape Shift, to Knee to Ankle, then edited the value without issue in the main tab, and it worked to give the poor girl short shins (in 4.10.0.123).
I get "measure metrics" and get don't an "edit" tab'
Correction: it shows and works if I use the script.
Good. The script is actually Figure Metrics, a PA product that uses the Measure Metrics plug-in, though they are bundled as a single product.
AAAAAAnd here I am again.
Fuigure:G8F
>Window>Panes>Measure Metrics
Yes, that's the Measure Metrics pane giving a readout of the measures. If you want to adjust them you need to run the Figure Metrics script, from Scripts>Utilities.
Is there a list of useful morphs that can be added in Measure Metrics to be edited with figure Metrics later? I always only have Bust, Chest and Waist and height defined. And it's sometimes quite hard to know what to pick. It would be good to have a checklist (or even better, already predefined settings) that could be loaded. I did not knew the one with the shin for example. I have a project, where I want to use as much of the real life Settings as possible, but I don't know how to bring them into DAZ. (or wich morphs will affect wich part , like the shins only).
