DSON importer to Poser 11 64 bit
Where in Hell do I install this?
It depends where you installed Poser. And if you're using DIM or not.
I don't use dim. dl'd and installed the program manually, which I think is the best option for this utility. (IIRC, P11 isn't an install option with DIM)
When you run the DSON installer, you'll get an entry field where you can select in which directory Poser is installed. You can click on the map icon on the right to browse to the poser directory (which in the example image is 'E:\Ppro11' as that is the directory where I installed PPro11.....)
I am opening DIM to see if I can install it via DIM, but I know there was a bug that prevented it to be installed to poser 11 pro with DIM.
https://www.daz3d.com/forums/discussion/225501/dson-importer-for-poser-pro-11#latest
thread in the Daz3d poser forum
Thank you! Problem solved with all your input!
