Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
OK. I think I got the BrunoD first face morph pretty much where I like it.
Side and front views.
I think I smoothed out my forehead problem but now I've noticed a problem in the teeth if you open the mouth. This is default Dawn showing the tooth problem. It may be a issue with fall off maybe?
In case anyone is interested, Xurge has Fantasy Rogue for Dawn for DS up now! :) One of the few things I've bought for her outside Hivewire. :)
Thanks for the heads up. Got it! :-)
Been working away on the torso today. Got a good bit of it modeled in now. Made some swim trunks for him too. Screen grab from DAZ Studio.
are there any merchant skin resources for Dawn out yet?
Her default texture is a merchant skin. It just can't be used for freebies. There's only one other merchant resource I know of so far, and it's just for her eyes.
http://www.renderosity.com/mod/bcs/eyezource/100332/
Where did you find the onfo on her default texture being a resource as long as you dont sell it? I'm not question your word I promise. I just don't want to miss anything.
From the Dawn Starter Pack. Select Dawn and the page will refresh. Scroll down to the "What's Included Features" and you will find these lines:
You'd have to sell it. It's freebies you can't use it for.
/edit
I found Biscuit has a lash MR for Dawn, too.
http://www.renderosity.com/mod/bcs/biscuits-dawn-merchant-resource-lashes/100224
Sorry my brain is not thinkig too well tonight. I meant. As long as you sell it. Dont give it away. Somehow blended together a bad sentence. Thanks for the resource links keep em coming if yall find more. I am having fun morphong her. Just need to texture her. I am making a texture but pores and seams are hard.
You're probably going to think I'm nuts, but look for a decent quality stock photo of the outside of a citrus peel (orange, lemon, lime, etc). Manipulate it enough and if you're lucky you can get something resembling pores.
You may also be able to do it by using a noise filter and adjusting the size/scatter amount.
I use pure noise. I create a sheet of noise, blur it, add more noise, blur that to a lesser degree and then add more noise. Then I turn the opacity down quite a ways to make it less black and white. Have a white later below it and then merge the two layers. Make a brush with it or use that as a basis for your pores and skin bumpiness. It's not going to work very well in areas like the tip of the nose since that will stretch out when it's morphed but for most large areas of the skin it's a good solution.
You two are great thanks for the info. The citrus peel makes sense and I would have never thought of that. The noise stuff though, I am unfamiliar with. I’m using Adobe Photoshop Elements 8.0 and Corel Paint Shop Pro Photo X2
Thanks in advance for any additional info that might be added.
Here is the noise map I made. You are welcome to use it.
Click on the picture to bring up the full size, right click and save as.
...that's a bummer. Other merchant resource kits allow either.
Not many MR kits allow freebies.
...that's interesting especially since most are paid for utilities.
I wish I knew-I never see these issues-and I've done many extreme morphs-including teeth to match the extreme head morphs.
What program do you use? I am using Zbrush
Here is another extreme morph that started as an answer to people complaining about linebacker shoulders and huge chins, etc-and ended up going way too far into the CUTE zone for MY comfort :-)
Greetings,
O_O¡
Shhheeeeees going to eeeeat meeeeeeeee!
Those teeth are filed to points...!
-- Morgan
I believe it's because depending on the amount of changes made you'd basically be giving their work away.
There are some freebie MRs out there that allow freebies, though.
I did not do anything when I found the tooth problem. Load default dawn. Open her mouth. Then move her jaw to the left and to the right and please see if her bottom teeth look like my post. Open mouth looks fine but when the jaw moves to the left or fight the teeth mess up. I think it is a fall off issue.
Ye the teeth go wonky if you move the jaw side to side on default Dawn.
Decided to take a break from BrunoD today. So made this morph. Hopefully she reminds you of someone! lol
Every morph I see of her still looks like a modified Gena Davis.
LOL - I think you are on to something there
I see the Teeth issue in Poser-I assume your are using DS? I'm going to make the people on the appropriate forum aware of this.
Thanks!
Yes that was a Daz version test.
Maraki for Dawn. I think this is the best render I've been able to do with dawn.
This is a PG version, you can see the unrated version in my Renderosity Gallery.
