Question for Stonemason
faisanfaisan Posts: 600
Why every I apart the camera on the urbanspwal2 the building seems to disapear? I thought it was the skydome, but I got invisible and it keeps same. I hope someone or stonemason can help me. Thanks!
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,250
    Do you mean in the preview screen or in renders?
    "Why every I apart the camera" may need to be further clarified...
    A screenshot of what you mean would really help to see what the problem is.
    Are you using Uber lighting? It has a dome to which can block out things in preview mode
  • JaderailJaderail Posts: 0
    It is very easy to find your camera inside a building in some of the sets. Just dolly your camera forward a bit and see if that is it. That would be Wheel back for a wheel mouse or magnifying glass and mouse back using the viewport icons.
  • faisanfaisan Posts: 600
    Here are the screenshots, if I move away the camera, the buildings start to dissappear. I don't know if I'm using Uber lighting, could you explain me better?
    1366 x 768 - 975K
    1366 x 768 - 1M
    I'd say this is your problem here. if you look at the second image you can see window frames in the view. You may need to delete/hide the building if you need that particular view.
    I'm not sure why it appears like an object encroaching in the distance but I suspect this is whats causing the issue.
    edited August 2013
    Since you're using Poser, you won't be using Uber lighting. Uber lighting in DS is a light dome for ambient occlusion, indirect light (IDL in Poser), IBL, etc.
    Post edited by Lissa_xyz on
  • FirstBastionFirstBastion Posts: 8,072
    Select the Main Camera and increase your yon value to a higher number. The default value works for portraits but big scene need to increase the farclip.,
    896 x 575 - 69K
    I'll try that, thank you for the advise! ;)
    Hey! it worked! Thank you so much! :D
  • TheWheelManTheWheelMan Posts: 1,014
    Damn! Even I didn't realize that!
    edited August 2013
    Glad I could help offer a solution and pass on the info.
