Skin Builder 3 Merchant Resource for Genesis 3 Female (Commercial)
12829303133
  • Any instrustions? I jsut installed this, I can find it under materials, but no actual files are there. I tried the Gen8 also and same thing. The files r in the zip and there when i unpack. I copy and paste everything over but nothing is there. Help would be appreciated
  • Where do I find the base images for the Anatomy/Genital support?  My copy does not have it.  What do I need to do in order to load it?
    Zev0 said:
    Welcome to the Official Skin Builder 3 Thread. Please post any product related questions here. Thank you for your support.
  • Zev0Zev0 Posts: 7,122
    edited December 2018
    Hi. Is the anatomy loaded on figure before skin creation? It needs to be present on figure when creating skin in order for it to be generated, then when you save it will be in your texture folder when you clicked on the create preset button (for anatomy).
    728 x 866 - 132K
    Post edited by Zev0 on
  • Hi there! I just purchased this and was super excited to see the skin color blend. I have a question though. Is there a way to change the single color to a pattern? I'd like to make a female skin with fur-like hands and feet with faux-fur partway up her legs and arms.
    edited January 2019
    Hi. The tutorial explains how to do that (Click on userguide button on main script interface). You definately can add in your own options. Look under the Modifying and Adding in options section. See how the current colorblend maps are designed and how they apply and follow that structure. You will however have to design or use maps that have the desired pattern. You could modify the texture from products that come with one, and drop it in SkinBuilder.
  • lbosslboss Posts: 0
    I have a big problem with that program... its loding forever and does nothing and than its going to crash... what can I do ???
  • takahanstakahans Posts: 4
    edited July 2020
    Hello, my question is the following .... How can I leave the Genesis 3 Female model skin by default? I know that by making mistakes you learn, but now the default skin color of my female genesis 3 models is different than it was before using the script, but using Nvidia Iray the skin color returns to normal, as if nothing would have happened .... is there any method to go back what I have done? Do I need to reinstall something in particular? Does the Script have any option to leave it as default? It would be great if you could answer me since I don't know who else to turn to, thank you very much =)
    1920 x 1080 - 264K
    Post edited by takahans on
    edited July 2020
    Hi. I need more information. This doesn't tell me much. The script does take time to build skin. Just let it run. If it has frozen please send me your log file.
    edited July 2020
    Hi. I'll need to know exactly what you did in order to fix this. If you want, you can redownload Genesis 3 Essentials and that will overwrite anything if something you did in SkinBuilder overwrote something.
    edited July 2020
    hello, at the time of loading the genesis 3 model, the model does not appear with the skin that comes by default, it appears with the skin that I create and now I do not know how to reverse that situation, I have just uninstalled and reinstalled the genesis package 3 essential female and no changes = (
    Ok click on the torso on the character skin and show mke what texture map is assigned.
    968 x 1440 - 403K
    Here is
    edited July 2020
    Then your skin is right, looks like it's just your default scene lighting settings that has changed in studio. This isn't SkinBuilder related.
    And how i cand do that?
    Open the Render Settings Pane in Studio under window/panes/render settings and set everything to default if something changed there.
  • If i want to change and go with less freckles how do i go backwards when i try to apply the lower setting it gets thicker.is there a way to start again.
    The script has Undo and Redo buttons. If you close the script you can use the standard studio undo and redo. It should undo the last thing you did to the skin.
  • That did not work i spent a lot of time on this model i dont want to have to redo it .is there another way to take them back off.i had already saved my changes on her last nite before i seen they were to thick.
    6016 x 2160 - 6M
  • Never mind i got it.yes Great product by the way i have quite a few of your products.
    Thanks for the support. Glad you're sorted.yes
    edited December 2020
    nm - changed mind, for those shopping this is a nifty product :-)
    Post edited by Catherine3678ab on
  • Is there an upgrade price to version 8 from Skinbuilder 3? Thanks.
    edited May 2021
    Hi. That offer expired when Skin Builder 8 was released. If it's a discount you looking for, then I'd wait till the product is on sale again.
  • Lately when I have used skin builder, I'd get missing files errors. Most of the time the skin builder still works, but sometimes I get off color effects. The first picture shows the error.
    The second picture shows the off-color. This is recent and its not uncommon for my Daz3D build to start popping up with weird errors that I have to troubleshoot to fix.
    Does anyone have any idea what the problem is?
    2560 x 1440 - 3M
    2560 x 1440 - 794K
    OK, thanks. It is a nice product but 50$ is too much for a tool that I have already bought once. My own fault missing the offer, I have only recently converted from gen3 to gen8.
  • kyoto kidkyoto kid Posts: 41,863
    ...keep an eye out for flash sales.
  • Zev0 said:
    Is there a thread for Skin Builder 3 that illustrates how to create skin texture for Genesis 3 Female Anatomy???
    Load the anatomy on the figure before using Skinbuilder. Make sure the figure is selected and it will build skin for both figure and anatomy.
    actually what i generally find is the script hangs... in about 20-30 seconds it builds textures for all but the anatomy, then hangs indefinately (most I waited was 24 minutes).  do i need to use a 3rd party anatomy to work with skin builder (I saw another post about hair)?  if so is there a recomened one or type?
    ...just curious as to why after creating the base skin why Skin Builder then selects surfaced like hair or a piece of clothing that isn't part of the character's skin?
    edited January 2022
    Hi. Can you give an example? Mine didn't select anything else. Just tried now with clothes and hair loaded.
    edited January 2022
    ...did the character have the gens geograft?
    For example on one character which also had the gens I had air content fitted as well as clothing (which I all turned off to view the progress on the skin.  After creating the skin the plugin next tried to work on the hair instead of the gens. I un-parented the and it next went to the shoes after creating the skin. I ended up having to un-parent everything the character was wearing for it to complete both the body and gens.
    Post edited by kyoto kid on
