[Solved]Materials of "Tribal Warrior Queen Outfit for Genesis 8 Female(s)" are unavailable.
qingliuhongtaiqingliuhongtai Posts: 43
https://www.daz3d.com/tribal-warrior-queen-outfit-for-genesis-8-females
I tried to install "Tribal Warrior Queen Outfit for Genesis 8 Female(s)" on DIM, but it said "Install Failed!".
And I downloaded manually, unziped, and copied to "My Library" directory.
The meshes can be merged into the scene, but the materials are unavailable.
So I installed on "Install" tab in DAZ Studio 4.10 Pro, but materials are still unavailable.
What should I do?
Post edited by qingliuhongtai on
  • What do you mean by unavailable - the files are shown i your first screen shot. Are you getting an error when you try to use them?
    The Material files are shown, but these cannnot be pasted to meshes.
  • TimotheusTimotheus Posts: 249
    I also got the "Install Failed!" error from the Installer. When I try to install manually from the downloaded zip, I get an "unspecified error" on several files....
    450 x 350 - 11K
    I also got  same error. "IM00055577-01_TribalWarriorQueenOutfitforGenesis8Females.zip" cannot be unziped normally.
    463 x 341 - 22K
    edited October 2018
    It's the actual texture files. Two folders are created in Runtime\Textures\Sade\TribalWarriorQueen: 1 and 2. Each has subfolders for each of the separate pieces, all of which are empty. When I install the textures expansion, which succeeds, I get textures in the "1" folder, and folders are added for 3-5, all of which do have their texture files. And I'm on Windows 10. Hope these details are helpful.
    Post edited by Timotheus on
  • While people are poking at this, can someone post what it looks like without the shoulder drape?
    edited October 2018
    Here's a really quick test render with some of the materials cobbled together.
    1000 x 1000 - 603K
  • reporting
  • DAZ_BrianDAZ_Brian Posts: 345
    This product has been updated as of 11:30 am MDT.
    Re download and try again.
    Thanks. Both installed correctly.
    Thanks
  • This problem has been solved! Thank you everyone!
    960 x 1440 - 831K
  • SadeSade Posts: 883
    i noticed and reported too, happy to solved <3
