[Solved]Materials of "Tribal Warrior Queen Outfit for Genesis 8 Female(s)" are unavailable.
https://www.daz3d.com/tribal-warrior-queen-outfit-for-genesis-8-females
I tried to install "Tribal Warrior Queen Outfit for Genesis 8 Female(s)" on DIM, but it said "Install Failed!".
And I downloaded manually, unziped, and copied to "My Library" directory.
The meshes can be merged into the scene, but the materials are unavailable.
So I installed on "Install" tab in DAZ Studio 4.10 Pro, but materials are still unavailable.
What should I do?
1446 x 1045 - 327K
992 x 583 - 64K
960 x 1440 - 808K
Post edited by qingliuhongtai on
What do you mean by unavailable - the files are shown i your first screen shot. Are you getting an error when you try to use them?
The Material files are shown, but these cannnot be pasted to meshes.
I also got the "Install Failed!" error from the Installer. When I try to install manually from the downloaded zip, I get an "unspecified error" on several files....
I also got same error. "IM00055577-01_TribalWarriorQueenOutfitforGenesis8Females.zip" cannot be unziped normally.
It's the actual texture files. Two folders are created in Runtime\Textures\Sade\TribalWarriorQueen: 1 and 2. Each has subfolders for each of the separate pieces, all of which are empty. When I install the textures expansion, which succeeds, I get textures in the "1" folder, and folders are added for 3-5, all of which do have their texture files. And I'm on Windows 10. Hope these details are helpful.
While people are poking at this, can someone post what it looks like without the shoulder drape?
Here's a really quick test render with some of the materials cobbled together.
reporting
This product has been updated as of 11:30 am MDT.
Re download and try again.
Thanks. Both installed correctly.
Thanks
This problem has been solved! Thank you everyone!
i noticed and reported too, happy to solved <3
