Echo Head Morphing Problem
2»
  • frank0314frank0314 Posts: 15,111
    If your using Win-Zip to extract your zip files just right click on it and select extract to, then select the location you want to put it. Once the file is extracted into the appropriate folder, check and see if it shows up in DS. If not, Rt click on the Content Library Tab, select Content DB Maintenance, Check off Re-Import Metadata, hit accept, Check off All Products box, hit submit. Let it do its magic and once done check to see if its there in your library
    The 'Required Products' is misleading, you don't need everything listed. If using generation 4 female figures which are Victoria 4 (base figure), Aiko 4, Stephanie 4 and Girl 4 (all morphs expansions) required would be Aiko 4 Base (not actually a base) and Victoria 4.2 Morphs++. If using Genesis required would be 'Genesis Evolution: Body Morphs' (personally I would recommend the Head and Body Bundle: http://www.daz3d.com/genesis-evolution-morph-bundle ) and 'V4 and M4 Shapes for Genesis'. If you are new to this I would recommend going with Genesis.
  • edited December 1969
    After giving up for week (has it been a week?) I stumbled across Echo in my poser library, and pressed the INJ icons one more time, and hey presto! she loaded.
    Time to turn up the juice and see what shakes loose!
