Importing LINES
richard.chaos_91798ec102
I have words I made in Made in Illustrator and WISH to put them in HEX and EXTRUDE it! How can I get this SHAPE into hex!
Save from Illustrator as a "Version 3 file" (not CS3). Make sure any fonts are outlined. With some versions of Illustrator you have to use the "Export" command to save to earlier versions.
In Hexagon use the "Import" command and select "Illustrator 3" in the Format menu. Your drawn Illustrator lines should then appear on screen.
Thanks man that was it!
