mcjShrinkWrapA for DS 4.5+ shrink wrap figures and objects - SAFE 2019 Update
124
  • RAMWolffRAMWolff Posts: 10,381
    COOL BEANS> looking forward to seeing this implemented! :-)
  • mCasualmCasual Posts: 4,607
    edited August 2013
    now that i'm back from the aiko-shoe-making detour
    i'll resume work on the shrinkWrapper script or plugin
    here you see in blue the profile of ... something wrapped onto something
    and in magenta, the convex hull that is supposed to give us a tent / spandex effect
    --- the second image clarifies the situation
    the line in green would be like a cloth stretched on top of the something
    and the line in magenta would be a hammoc on which the something lays
    and you know what all this reminds me of ? .... this ... http://www.youtube.com/watch?v=AOiuh2Upa8s
    Turns out what i want has a name, it's called Andrew's Monotone Chain Algorithm
    http://en.wikibooks.org/wiki/Algorithm_Implementation/Geometry/Convex_hull/Monotone_chain
    1280 x 447 - 86K
    686 x 822 - 82K
    1280 x 720 - 85K
    863 x 424 - 43K
    863 x 424 - 43K
    Post edited by mCasual on
    My head hurts from the technical stuff! lol Still watching and hoping you can get all this working even better than before. :coolgrin:
    some progress! i caught the moon in a net
    not there yet but that's progress, the curve shows how the "spandex" part of the script would treat a cloth shrink-wraped onto a ball+floor
    800 x 900 - 287K
    Very nice but do you think there is a way to even out the curvatures where the verts on the ground are more gradual up to the verts where they are more populated on the moon ball??
    Looking at your dialog your working in what would happen if you spaced out the dots more evenly from the ground to where that first dot is up on the curve on either side??
    i had an experimental version where, as a last step, i reconstructed the curves/loops by first measuring the loop. then spreading the vertices at constant distances, i could add that as an option.
    but this wont affect the shape of the curves which are like rubber-bands under tension
    it's not a simulation of an elastic knitted cloth, in fact for now its just rows or columns of rubber-bands along one axis
    when i'll combine 2 axis it should give interesting results
    one thing i may also do is a tapering effect based on something like the D-Form's weights
    in the distant dream future i'd like to add semi-random wrinkle/folds in the areas that are not in contact with the wrappee
    edited August 2013
    oh but actually in the script, ( my laboratory version, that is ) presently, there IS a system that "re-populates" the curve, it's just that in the previous plot they were not computed , but in a forum post before that one you could see how the curves had the same number of vertices at the end of the process
    so it would look more like this
    723 x 343 - 27K
    Ooo, now were talking! That's lovely!
    edited August 2013
    Fig 1 - a momentous event, the first time the script came up with an acceptable rubberband effect for ribbon/plane wrappers
    Fig 2 - corrected interpolation issue
    Fig3 - complex case
    Fig 4 - improved
    Fig 3 - stuff to look into
    1128 x 642 - 347K
    1136 x 644 - 125K
    1078 x 808 - 183K
    850 x 638 - 167K
    840 x 630 - 169K
    This is just awesome! WOW!
    had some fence issues to solve ( is a flat line concave or convex? asked the computer )
    next time i should have the first example of lets call it a spandexish mesh
    1280 x 720 - 648K
    WHOA, that's looking perfectumundo! Getting the shrink wrap to work over many areas of the body will greatly benefit from the new improvements.
    Still here too. Haven't got a clue how you do all that, but it looks like it'll be fun to play with ... web wires, forcefields, ...
    edited August 2013
    i think my characters are getting tired of the spiderman tests but they wont mind having new clothes done with it
    920 x 528 - 94K
    1920 x 1080 - 499K
    Okay :-)
    That last one with the kick is just unbelievable. WOW!
    edited August 2013
    another lab test which was a good idea since it let me discover a tiny rarely ocuring bug in the phase where the script discovers the architecture of the wrapping cloth
    ( it holds in place using nanotechnology )
    800 x 1200 - 387K
    800 x 1200 - 219K
    533 x 800 - 110K
    I like the third image with the red as the verts look more nicely spread out under the breast area! Perhaps there is a way to include a spreading smoothing option to make sure tighter areas won't get bunched up??
    Considering the hours I just spent trying to get a uvmap in Hexie for that area "presentable" ... WANT!!!!!
    to get this result, i made a first shrink pass, then i decimated and subdivided the bustier/shield
    then i re-shrunk it
    maybe there will be "rebuilding " of the curves to spread out the vertices ... maybe soon maybe later :)
    didn't advance the script but i made a little demo video !
    http://www.youtube.com/watch?v=mpC8fFnq8vg
    ? would there be a better result for the box if it was tessellated a lot ... like the sphere was?
    Yea, exceptional examples but the box was a little weird.
    the wrapper is projected onto the wrapped objects at a perpendicular angle from the wrapper plane (normals )
    some collider rays hit the box others hit the floor, then the script pulls them back a little - to reduce poke-trough
    but in this case the poke-through is as tall as the box so it doesn't work, then the spandex effect is (optionally ) applied
    and this too isn't enough to solve the poke through
    to really really solve poke-trough, the script would check each one of the 4096 edges of the wrapper plane and move them so that they
    don't pierce the cube .... but i'd leave that for later
    for now the air-gap is enough to fix poke-trough enough to help make clothes for figures
    1280 x 720 - 58K
    edited August 2013
    by pre-shrinking the wrapper plane and using a larger air-gap we get rid of the poke-trough
    note here that the spandex / rubber-band effect is still only along 1 axis but should be available along 2 axis
    1280 x 720 - 298K
    1280 x 720 - 353K
    Very nice. Perfect even!
    You know, it occurred to me that perhaps you might actually develop a dynamics engine for DAZ Studio that can take simple obj's and drape them and then work up to more complex or outfits that were previously made. One of the factors that is gravely missing from DAZ Studio is a way use common and complex shapes to drape at the end users convenience rather than relying on that other system (which to me is too limiting).
    edited August 2013
    an important step for the script ( though i was holding it by the hand )
    the sort-of-spandex effect along 2axis
    the the script does
    - push the cloth against the cube, as if it was a wet t-shirt
    - stretch the cloth fibers along the X axis
    - stretch the cloth fibers along the Z axis
    Figure 2
    maybe the essence of this script is cup / hat / tent making
    1280 x 720 - 570K
    1280 x 720 - 469K
    a first garment-ish result with the 2 axis sort-of-spandex effect!
    800 x 1200 - 276K
    Oh that's going to be popular!
