Daz Freezing up When using Transfer Utility.
acharyapolina
Hi, I am back again. :P So I am again having the same problum as before. Some of my models go through and so cause my daz studio to Freeze up,. I am trying to create a wearable helmet for my character, but as I go through the process of using the transfer utility it freezes on 22%. I dont know what is causing it. I have tried everything I can think of.
Any help is very greatly aprciated. Thank you so much!!!!
Post edited by acharyapolina on
I figured out my problum. I needed to convert my 3D prop model into a figure first. by going to Edit. then Object then Rigging then convert prop to figure. After that the transfer untility works fine. :)
It looks like you found a workaround but not a fix to the problem. I'll try the workaround but I hate there is no fix and adding extra steps. But thanks you are a life saver. DAZ needs to fix this.
Oops didn't work. Any suggestions?
It would be great if someone savvy in Daz programming could make a script to manage this sort of thing *hint, nudge ;p
