Using Genesis Clothing in Fitting Room to Fit to Previous Generation Figures?
Headwax
Hya, just wondered if there was any problem fitting Genesis clothing to other figures in the fitting room?
I don't have any clothes belonging to genesis, and I don't use Genesis.
but I am a DAZ PC member till end of December and
as you may/ may not be aware, often the 1.99 items daz brings out are soley for Genesis
which appear to be useless unless you use Genesis.
So I just wondered if we could use these clothes via the Poser 2014 fitting room?
And if there was a particular work flow I needed?
I guess I need the dson importer for a start?
thanks in advance for any replies
edit: guess I found the answer partial on another site whose name I cannot tell you because I will be....
Genesis clothing to other figures, you just need to export the clothing from DAZ Studio as a Poser CR2 file, then convert it normally.
•To convert
yes, it is probably best to use the dson importer so you get all your textures imported nicely.
I think it should work. haven't tried it myself though . let me k now how it works out please.
thanks esther, when I get some I'll let you know!
ironically I was just replying to one of your kind remarks on the poser 2014 forum on another site (one about fighting politicians)
cheers from ere : )
and the church. saw it. good luck with all of your projects. keep me posted.
