Using Genesis Clothing in Fitting Room to Fit to Previous Generation Figures?
HeadwaxHeadwax Posts: 10,566
edited July 2013 in Poser Discussion
Hya, just wondered if there was any problem fitting Genesis clothing to other figures in the fitting room?
I don't have any clothes belonging to genesis, and I don't use Genesis.
but I am a DAZ PC member till end of December and
as you may/ may not be aware, often the 1.99 items daz brings out are soley for Genesis
which appear to be useless unless you use Genesis.
So I just wondered if we could use these clothes via the Poser 2014 fitting room?
And if there was a particular work flow I needed?
I guess I need the dson importer for a start?
thanks in advance for any replies
edit: guess I found the answer partial on another site whose name I cannot tell you because I will be....
•To convert
Genesis clothing to other figures, you just need to export the clothing from DAZ Studio as a Poser CR2 file, then convert it normally.
Post edited by Headwax on
  • estheresther Posts: 641
    yes, it is probably best to use the dson importer so you get all your textures imported nicely.
    I think it should work. haven't tried it myself though . let me k now how it works out please.
    thanks esther, when I get some I'll let you know!
    ironically I was just replying to one of your kind remarks on the poser 2014 forum on another site (one about fighting politicians)
    cheers from ere : )
    and the church. saw it. good luck with all of your projects. keep me posted.
