RSSY Iray to 3Delight Converter
1468910
  • TooncesToonces Posts: 919
    Regarding the 3DL to Iray, one thing I've noticed when running it against old products -- the General Iray Shader doesn't copy diffuse color to base color. The base colors are always set to white. This is OK if there's a texture, but some older stuff just relied on diffuse color alone.
    I do like the General Iray Shader, so I'm assuming it had to set the color to white to work it's magic...but I'm curious if there is some other similar shader out there which will honor the diffuse colors and copy them over...other than plain ole iray uber shader.
    Also, I got the update for the 3DL to Iray product today, and it seemed to break the selection mechanism.
    Select None disables 'Apply Presets'.  But even when I manually check a few of the items, 'Apply Presets' does not re-enable. Even if I manually check ALL the surfaces, it still doesn't re-enable. The only way to get it to re-enable is to select Select All (which defeats the purpose if you only want to run it for a few surfaces) or Find Matches again.
    Clicking Find Matches again is a decent workaround, but I'm pretty sure this was working before the update (i.e., you could just click the checkbox for an item and it would re-enable Apply Presets).
  • DkgooseDkgoose Posts: 1,451
    edited June 2018
    Post edited by Dkgoose on
  • BeeMKayBeeMKay Posts: 7,019
    Just wanted to say, the Iray to 3DL converter works beautifully on the Dog 8. I only had to change the eye moisture afterwards to water, as it was translated to standard shader.
  • RiverSoft ArtRiverSoft Art Posts: 6,947
    This fix will be coming out in another update.  I can preserve the color.  I rushed out a fix to make sure the script wasn't broken by the update to the Iray to 3DL.
    Thank you for reporting this bug.  I will make sure it is in the next update.
    Hi Bee!  Thank you for confirming it.  I am glad you like it.
  • Charlie JudgeCharlie Judge Posts: 13,612
    edited June 2018
    I just purchased the RSSY 3DL to Iray converter and installed with DIM. However the scripts are not showing up in my content library and it appears that they may not have been installed. See attached screen shots. I have tried unistalling and reinstalling several times but always with the same result
    Please advise. I was hoping to try this on a couple of my favorite old 3DL scenes.
    519 x 544 - 56K
    588 x 698 - 236K
    Post edited by Charlie Judge on
    That is really strange.  If I open the official zip file itself, the script is under Content->Scripts->RiverSoft Art->3Delight To Iray.  What do you see?
    If I manually dowload the zip file I can see the scripts; but when I install withDIM they evidently do not install I'm not good at manual installations and always use DIM
    edited June 2018
    Here is the DIM install log entry:
    Installing product : RSSY 3Delight to Iray Converter
    File: Content/Scripts/RiverSoft Art/3DL to Iray/RSSY 3Delight to Iray Manual.dsa was in manifest but not found in zip : RSSY 3Delight to Iray Converter
    File: Content/Scripts/RiverSoft Art/3DL to Iray/RSSY 3Delight to Iray Manual.pdf was in manifest but not found in zip : RSSY 3Delight to Iray Converter
    File: Content/Scripts/RiverSoft Art/3DL to Iray/RSSY 3Delight to Iray Manual.png was in manifest but not found in zip : RSSY 3Delight to Iray Converter
    File: Content/Scripts/RiverSoft Art/3DL to Iray/RSSY 3Delight to Iray.dse was in manifest but not found in zip : RSSY 3Delight to Iray Converter
    File: Content/Scripts/RiverSoft Art/3DL to Iray/RSSY 3Delight to Iray.png was in manifest but not found in zip : RSSY 3Delight to Iray Converter
    File: Content/Scripts/RiverSoft Art/3DL to Iray/RSSY 3Delight to Iray.tip.png was in manifest but not found in zip : RSSY 3Delight to Iray Converter
    Product successfully installed : RSSY 3Delight to Iray Converter
    Install Queue finished in 0 min 1.2 sec.
    Saving Account Settings: Account
    Edit to add: I have gone ahead and submitted a help ticket
    That is what I was going to recommend.
  • Faeryl WomynFaeryl Womyn Posts: 3,771
    I don't use DIM, I manually download and install. I got the Iray to 3DL on the 13th, do I need to redownload and reinstall due to the update I was just reading about?
    I am happy to report that the scripts are now properly downloading and installing with DIM.
    Yes, you need to download and install to get the last update.
    Great!  Happy to hear it.
    New updates are availabe from DIM as of yesterday.  These updates should fix both issues.
  • sapatsapat Posts: 1,735
    edited June 2018
    I downloaded a file from DIM and let it install, but how do i know it's the one from the 22nd?  Here's a snippet from some page that says UD was 06/19/18.  I never use DIM, so I have no clue how to make sure the one I got is the newest.  You have to click on the attachment to see the image properly.
    thanks.
    636 x 103 - 15K
    Post edited by sapat on
    thanks.
    Yes, that is the latest.  that was the fix I submitted.
    thanks.
    Great, thank you!!
  • wsterdanwsterdan Posts: 3,544
    I’ve downloaded the updates for both products. I apply a blue-skinned preset from Beautiful Skins — Iray, run the Iray to 3DL script and the blue disappears. Is this something that was supposed to be updated, is it something that is still gong to be updated, or am I just doing something wrong (which is usually my default assumption))?
    — Walt Sterdan
    — Walt Sterdan
    Hi Walt, I don't have that product so I can't say exactly.  The script should preserve the color in Base Color and put it in Diffuse Color.  If it is map, it is preserved.  Does Beautiful Skins put the color somewhere else?
    Hi;
    It doesn't appear to work for me, unless (as I mentioned might be a possibility) I'm doing something wrong.
    Before and after picts attached.
    -- Walt Sterdan
    632 x 284 - 44K
    719 x 251 - 46K
    Yeh, I was having the same problem with the 3DL to Iray converter.
    I will say, after the latest patch, the color is copied successfully and the 'Apply Presets' button works great! Thanks for the speedy fixes to the 3DL to Iray product!
    wsterdan said:
    Hi;
    -- Walt Sterdan
    I just tested it again, and it is working for me.  When did you download the latest updates?  If you look in the zip, what is the file date on the Iray to 3DL script?
    Hi;
    Thanks for the prompt service, always appreciated!
    I removed it, re-downloaded it using DIM, same results. I'm currently running it using the default settings, is there something extra I'm supposed to be checking? At this point, I'm going to assume it's me, not you. wink
    - Walt Sterdan
    528 x 266 - 72K
    wsterdan said:
    Hi;
    - Walt Sterdan
    Never underestimate my power to get it wrong. smiley Mine says June 21, 7:08a.m.  (I assume the hour difference is the time zone).  How about the RSIrayTo3DLFunctions.dse file, mine is June 22, 5:21 AM?  Have you tried it with other Iray stuff?  Drop something simple in the scene, change the Iray Base color yourself and try the script.
    - Walt Sterdan
    May 22.
    352 x 184 - 21K
    wsterdan said:
    - Walt Sterdan
    May 22.
    My bad, yes, May 22.  So that looks right.
    Have you tried the script on something else?
    Yes, that worked. I tried three different objects, all retained the colour when converted.
    -- Walt Sterdan
