Ready !! - mcjA3CropTop -- Summer Crop-top for Aiko3
13»
  • mCasualmCasual Posts: 4,607
    checking out the hem shapes and their UV map
    the sewn threads are a simple tiled dash texture
    1280 x 720 - 183K
  • M F MM F M Posts: 1,388
    edited June 2013
    What's the little red triangle just at the base of Aiko's left-side strap, in the very lower-right there? I hope it's not blood... (o.o).
    (everything is so perfect that blemishes really stand out <(^_^)).</p>
    Will the strap around her waist still have hems too? I really really love modelled hems (^/\^) - they look so much more professional than just a simple "tube" or "flat sheet" of material (like a certain other recent release #27 in a certain otheR Market Place - which, while textured nicely... just looks soooo... hasty, in the non-textured promo shot >_<).</p>
    btw I was thinking about how she might go about putting it on -- if there was a vertical hem down the middle of the piece around her waist, perhaps for buttons (or a zipper, or laces?) that would make life a lot easier for her ;-).
    All $0.02c of course -- do as you feel inspired to <(^_^).</p>
    400 x 381 - 99K
    Post edited by M F M on
    edited June 2013
    All $0.02c of course -- do as you feel inspired to <(^_^).</div>
    it's an issue with the way the hem generator turns the corner
    i have to make it build 2 more loops. One of the ideas is that
    one could make the hems invisible, and the paper-thin shell
    could have custom hems done using bump/displacement/normal maps
    yes the waist will have 2 hems larger and thicker
    i think i'll make 1 material per hem so you can turn off the ones you dont like
    don't know if you saw it but the real life inspiration for the crop top is
    http://www.rayout.cl/wp-content/gallery/mikie-hara/mikie-018.jpg
    http://shareyourwallpapers.com/upload/wallpaper/celebrities-female/mikie-hara/mikie-hara_905cb01d.jpg
    http://www.saladpuncher.com/bachelor/wp-content/gallery/mikie-hara-image-tv-ready-steady-go/mikie.hara.32.jpg
    1322 x 558 - 118K
    Post edited by mCasual on
    high-waistband hems added
    927 x 1200 - 195K
    edited June 2013
    figure 1 : the hem generator is complete < sent from my Vic-20 >
    figure 2 - BreastSize4
    unfortunately, when i fixed problems with this morph i lost some tension
    6134 quads for the hems
    3072 quads for the crop top
    that's very light i'd say yet very curvy
    ( ok i didn't really send it from my vic-20 t'would be possible though )
    772 x 1000 - 118K
    1920 x 1200 - 303K
    edited June 2013
    the 18 sets of hems are ready
    i hope the next time i do a top , it will take 10 times less effort and time :)
    Figure 1 : BreastSize2
    Figure 2 : Default Aiko3 body
    Figure 3: BreastSize3
    Figure 4: Muscular
    Figure 5: Cleavage
    1280 x 720 - 221K
    1280 x 720 - 191K
    1280 x 720 - 183K
    1280 x 720 - 181K
    1280 x 720 - 180K
    edited June 2013
    more views
    Fig 1 - Brst Natural
    Fig 2 - Stylized
    Fig 3 - Realistic ... Hey at last at last we get to see the ducks !!
    Fig 4 - BrstDiameter
    Fig 5 - BreastLift
    1280 x 720 - 149K
    1280 x 720 - 213K
    1280 x 720 - 207K
    1280 x 720 - 262K
    1280 x 720 - 241K
    edited July 2013
    the hems about to go through UV-beautification
    Figure 2
    a script goes through the hem's rings,
    for each ring, the vertices are projected on the plane passing through the green and red vectors
    then the vertex is projected on the red and green vectors
    this gives us x and y coordinates which are used to rebuild the UV map
    Figure 3
    later that day .... mostly done ! i have to improve corners but that will help improve the look
    as we'll see in figure 4 ...
    204 x 382 - 16K
    1024 x 576 - 121K
    978 x 559 - 193K
    500 x 281 - 61K
    900 x 675 - 218K
    edited July 2013
    front view
    i'll probably add some morphs to tweak the hems ( width thickness roundness )
    figure 2 -- i "manually" fixed the corners
    figyre 3 - the material zones for the shell
    figure 4 - template for the shell
    figure 5 - the new UV map was transfered to the 17-morphs crop-top
    444 x 444 - 501K
    800 x 800 - 139K
    800 x 800 - 106K
    1600 x 900 - 222K
    1920 x 720 - 211K
    edited July 2013
    i'm sure everyone is as elated as i am to find out the crop top hem's UV map has been transferred to the crop top hem's 18 shapes -- also, Amy in Akihabara demonstrating the hand trick that lets you figure the direction of the vector resulting from the cross-product of two vectors
    video ! https://www.facebook.com/photo.php?v=10152014382544746&l=5694008934021107689
    just tell your brain that she's floating 4 ft above ground, and flying around the google-street-car's roof-top-camera
    864 x 864 - 175K
    1280 x 720 - 65K
    864 x 864 - 146K
    edited July 2013
    C r o p - T o p N e w s
    minor change ( but hey )
    the hems for the top part now have an un-wrapped UV map instead of a projected-through UV map
    almost ready for the rigging phase and the collar-bend morph creation
    so hopes are now for a weekend release
    864 x 864 - 94K
    864 x 864 - 173K
    864 x 864 - 107K
  • English BobEnglish Bob Posts: 118
    I'll almost be sorry to see this released - I've enjoyed watching the creation process. (I did say "almost"!)
    I'm assuming that a transmap for the Bodycon was used to assemble the dress in the vector demonstration images? I might not use this as a crop-top very much, but the combination makes a great party dress.
    i used the soon to be released second version of mcjShrinkWrap [http://www.daz3d.com/forums/discussion/24707/] to shrink wrap Aiko3-Stylized's body using a tube.
    it's basically the way i built the bodycon,
    indeed the bodycon coul've been used, i did use it with a transmap as a miniskirt in ...
    400 x 800 - 57K
    Thanks, I saw the mini-skirt transmap and, indeed, downloaded it. That's what made me suppose you'd done the same to make the dress.
    I can soon put together something of my own to make a crop-top-party-dress, probably using Poser dynamic cloth for simplicity's sake.
    edited July 2013
    fashion wise you can see it's easy to just blend in with the crowds
    1280 x 720 - 144K
    1280 x 720 - 175K
    edited July 2013
    crop top news
    so today may be the day i'll publish the crop top
    here you see the mesh has been turned into a figure
    i have to create the collarBend morph, re-apply the 17 morph shapes we saw so far
    and i guess that will be it :)
    Figure 2 -- as previously stated, i wont put much work in the creation of the collarBend morphs ( i used simple dForms in DS3 )
    personally i often zero and lock the collar nodes on Aiko and sometimes transfer the rotations
    from the collar joints to the shoulder joints
    figure 3, the 2 DForms (collarBend ) were exported then embedded in the CR2 figure
    figure 4 when it's part of an animation it doesn't look too bad even at extreme collar-bend angles
    figure 5 ( later that day ) the 17 morph shapes were converted into 68 morphs since figures are composed of 4 bone-meshes ( i work in DS3 you see )
    768 x 1024 - 402K
    424 x 600 - 233K
    424 x 599 - 120K
    800 x 800 - 161K
    424 x 599 - 146K
    edited July 2013
    *** Crop Top News *** *** Crop Top News *** *** Crop Top News ***
    the crop top is 99% completed i just have to add the "highbeams" morph
    and maybe do a test or two
    then make the release web page
    the very seriously expected release date/time is Sunday AM
    1280 x 720 - 116K
    576 x 768 - 87K
    it's ready !!!! yay yay !
    https://sites.google.com/site/mcasualsdazscripts3/mcjacroptop
  • rlowensrlowens Posts: 37
    Thank you, but it's not quite ready just yet... Forgot to include the .obj in the zip file :D
    edited July 2013
    thanks !
    i uploaded a new version which includes the runtime/geometries/mcasual/mcjA3CropTop.obj file :)
    https://sites.google.com/site/mcasualsdazscripts3/mcjacroptop/mcjA3CropTop.zip
    Thank you :D
    i guess it goes without saying but, i start a scene, i load Aiko3, put a skirt on her, and i go, "now i have to add a top" and .... well i have one right there ! :)
    Thank you! (^/\^).
    Well, I went about things the other way around - I loaded Aiko 3, put a top on her, and so of course I had to add a skirt. You might recognise the boots though!
    Thanks again for this, it works very well.
    475 x 675 - 25K
    looks great!
    which reminds me i didnt conclude the Aiko3 pumps project
    800 x 800 - 117K
    Ah, I see you're right - they're labelled 'beta', although they seem to work all right. What's left to do?
    hems so they don't look paper-thin and maybe some morphs, they only fit the default Aiko3/Aiko3LE body
    i also wanted an open-toe version
  • none01ohonenone01ohone Posts: 862
    Thanks for the freebie Casual.
    It's been interesting to read through this post and your shrinkwrap post, to see how the modeling process evolved.
    I've seen many products with deformed textures, but yours look perfect.
    Time to dig out Aiko3.
    edited August 2017
    If you have problems with old Generation 3 clothes ( like my free mcjA3CropTop ) with Daz Studio 4.9, try fitting them with the wearer figure zero-posed - more work but better than never using that item ever!
    1000 x 1200 - 167K
