Do you think Clothes for G3 modeled better than for G2?
davesodaveso Posts: 8,215
why buy new new when you can get older for cheap?
Is the quality any better really..to spend 10% more like in current huge sale?
    I think they're equally good generally and I still use G2 clothing, even on G8. Shoes can be a little tricky sometimes, but most clothes fit with a little smoothing.
    Laurie
  • FSMCDesignsFSMCDesigns Posts: 12,855
    daveso said:
    Works great and definately needed for the clones to fit older clothing to G3
    the problem with older vs newer clothing isn't a quality one, it's a fit one. When you autofit you can lose quality and integity because the rigging is different and this can warp the mesh and stretch textures. I use older clothing all the time, some works great, some not so much. It all comes down to how picky you are with the final results
  • nicsttnicstt Posts: 11,715
    Sometimes autofit makes things worse; instead try positioning, scaling and adjusting.
    Other times a quick dforce works well.. actually better as clothes look like they are cloth, not a facsimile thereof.
  • SaldazSaldaz Posts: 168
    What if you render iray and G2 clothing is not optimised for iray?
  • HavosHavos Posts: 5,692
    You can easily change the shaders and most clothing items. Some might use textures with burnt in shadows/specularity (although this is rare even for older clothing textures), but you can often swap the textures with new ones as well.
