The I Must Be SMART Thread
1234689
  • SaldazSaldaz Posts: 168
    There are no black dots.  They are the illusion.  Walk away from the screen and look at it from a distance.
    I saw them so they must have been there
  • LeatherGryphonLeatherGryphon Posts: 12,498
    edited June 2018
    kyoto kid said:
    Go stand outside and you can't even see the computer.smiley
    More to the point. copy the image to another page and magnify it to the max. The black dots are there, each surrounded by a white outline. I can't on the other hand see them all at once (which might be my own diabetic eye damage at fault. (No offence meant.)
    ...it plays with the "blind spot" on your retina.  I remember an interesting test we did back in school to illustrate it.
    surprise I'll be jiggered!  I thought it was a refinement of the phantom dots seen in the crossing points  of horizontal & vertical gray lines on a white background. yes
    Perhaps this one works so well on me because I have more than one blindspot in each eye and I've got crap floating in the middle of my eyeball too.  I see things disappearing and floating around all the time. frown  For the last week the crap in my left eye has moved closer to the retina and I see sharply focused tiny little black dots that look like ants crawing on my arm.  I've swatted at them a couple of times. blush  Then as I move my eyes quickly the spots fly into the air and float to a new spot. frown
  • kyoto kidkyoto kid Posts: 42,427
    ...yeah I have "floaters" in one eye as well.
    What I did was lean back and focused above the centre that way I could see all 12 at the same time.
  • VIArtsVIArts Posts: 1,539
    Being a visuallty impaired guy with a magnified screen, i counted ne by one ad got 12
    How can you add eight 2s together so that they make up a total of 250?
  • SimonJMSimonJM Posts: 6,101
    Ask a 5 year old
  • TJohnTJohn Posts: 11,446
    200+20+20+2+2+2+2+2=250
  • XyetztXyetzt Posts: 27,554
    SimonJM said:
    Ask a 5 year old
    Can I ask a seven year old instead.  He used to be five but that was two years ago!
    not quite, you only need the 2s, not the zeros
  • Richard HaseltineRichard Haseltine Posts: 111,504
    222 + 22 + 2 +2 + 2
    222 + 22 + 2 +2 + 2
    ...my math coprocessor goes offline at 00:00 for scheduled overnight maintenance.
    no complex calculations tonight then :(
    Bitter or sweet
    A little or much
    Soft and light or hard and heavy
    Builds or destroys
    And from it, none can flee
    What is it?
    Oh I was going to ask this question; if someone had a ton of coins in the back of a Silverado truck and tried to give the truck and money for you for a dollar or he will keep the truck and coins and give you a check for $40,000.  Assume the truck is in good conditon (aka it runs well even with a ton of coins in the back) and also the amount of each value of coin is random and unknown. The truckbed was lined to keep the coins from falling out.  The coins are a mixture of current currency.  To the seller's knowledge there are no paper form of money in it.  The only reason he is charging you a dollar for the truck is because he had to charge you something to consider it a sale.  No matter which one you choose, he would like you to do one of the following; Create a short computer animation or teach him how to use his computer and to use 3D software on it or help him find a freelancer who can make his movie for him.
    Which would agree to help this man? If so, would you get the truck with all the coins in it or the check?
    edited June 2018
    Upon on quick reflection, I'd take the truck as long as it was not an ancient wreck, and in good working condition, and if he also provided all the paperwork to prove it is not stolen and now legally transferred.  I would take the truck instead of the $40,000 check regardless of the value of the coins in the back.   A decent truck itself has value.  A check is too easily cancelled but a ton of coins is not.  Assuring that I would definately come out ahead on the deal rather than ending up with nothing.
    HOWEVER, that is only my opinion upon quick reflection.  I have no idea of your capability to satisfy your end of the bargain nor do I know to what extent the giver would go to extract retribution should you fail to meet his needs.  Nor have I calculated the possible range of values of the coins.  Assement of risk vs reward is a good idea in any case.
    I have seven minutes to get to work.
    it's Smarterday
    Ahhh chooo!
    edited June 2018
    Smarter cat on smarterday
    Post edited by Chohole on
    Lol! Good job kitty!
    “Just because I gained two pounds since last vet visit,does not mean I need to go on a diet!”
    1536 x 2048 - 568K
    If I eat some smarties will I get smarter?
    it is but wortha try
    As long as you brush your teeth frequently or you will probably get cavities. 0.o
    i fell out of my chair and boinked my smartness carrier...
    ...I would go for the Canadian ones as they appear to have a time release coating.   Not all that good to get too much smarts all at once.
    Who is the best Daddy ever?  A lot of places are advertising for me to get something for the best Daddy ever.  I want to make sure I get something for the best Daddy ever.
    edited June 2018
    800 x 488 - 153K
    Post edited by VIArts on
    Lint.
