Drillhead for Tunneling Machine Mystery
Retro Lad
In 2003 I used Bryce 4 to make an image of a Victorian type "earth tunneling" machine. The spiraling "drillhead" for the machine I modeled in Ray Dream Studio, which later became Carrara.. But I can't remember how I made my drillhead. I must have made it using the Spline options, somehow.
Anyway, I attached a closeup of my 2003 Ray Dream drillhead, and if any of you can duplicate it, or even improve on it, I would be grateful for the help.
Post edited by Retro Lad on
You could start it in the spline modeler using a preset in the geometry menu.
you could also do it in the vertex modeler. More than one way, but might try using a shape and a poly line.
Silly, but could also experiment with primitives and the black hole modifier.
I like the project. Great images.
a threaded screw. i was just trying to make 1 of those. couldn't figure an easy way to do it.
i'm battling a co worker right now against his cad s/w
a spline spiral on a cone
th3Digit wrote, "a spline spiral on a cone"
That may have been the way I did it many years ago, and then booleaned the two. So many things to recall and to learn. I will post some new tests soon. Frequent Walgreen caffeine tablets help.
i had him at add thickness, but lost at the screw thread.
his lite cad cant export out as an obj.
It was in Bryce 4 that I made the Drillhead, using it's odd boolean method. I must have made the spiral in Ray Dream (Carrara) and then brought it into Bryce for booleaning with a cone.
I did some brief tests using Carrara and Hexagon to make the drill and it was a pain in the arse. Bryce does it quickly. So Bryce is still very useful for some tasks even though it has been kicked out into the cold, cruel, world.
