Drillhead for Tunneling Machine Mystery
Retro LadRetro Lad Posts: 472
edited June 2018 in Carrara Discussion
In 2003 I used Bryce 4 to make an image of a Victorian type "earth tunneling" machine. The spiraling "drillhead" for the machine I modeled in Ray Dream Studio, which later became Carrara.. But I can't remember how I made my drillhead. I must have made it using the Spline options, somehow.
Anyway, I attached a closeup of my 2003 Ray Dream drillhead, and if any of you can duplicate it, or even improve on it, I would be grateful for the help.
1000 x 750 - 82K
640 x 480 - 23K
Post edited by Retro Lad on
  • DiomedeDiomede Posts: 15,459
    You could start it in the spline modeler using a preset in the geometry menu.
    you could also do it in the vertex modeler.  More than one way, but might try using a shape and a poly line.
    Silly, but could also experiment with primitives and the black hole modifier.
    I like the project.  Great images.
    a threaded screw.  i was just trying to make 1 of those.  couldn't figure an easy way to do it.
    i'm battling a co worker right now against his cad s/w
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,602
    a spline spiral on a cone
  • Retro LadRetro Lad Posts: 472
    th3Digit   wrote, "a spline spiral on a cone"
    That may have been the way I did it many years ago, and then booleaned the two. So many things to recall and to learn. I will post some new tests soon. Frequent Walgreen caffeine tablets help.
    i had him at add thickness, but lost at the screw thread.
    his lite cad cant export out as an obj.
    It was in Bryce 4 that I made the Drillhead, using it's odd boolean method. I must have made the spiral in Ray Dream (Carrara) and then brought it into Bryce for booleaning with a cone.
    I did some brief  tests using Carrara and Hexagon to make the drill and it was a pain in the arse. Bryce does it quickly. So Bryce is still very useful for some tasks even though it has been kicked out into the cold, cruel, world.
