so if an animation is saved using genesis it works on Genesis 3
2
  • marblemarble Posts: 7,500
    th3Digit said:
    Tryhard said:
    So I got it figured out. Here's how you get Mixamo animations work with Genesis 8.
    1) Download the desired animation as FBX from mixamo (I used Aiko 6 as fbx avatar)
    2) Open up Daz3D
    3) Import the FBX from mixamo
    4) load up Genesis 1 figure
    5) select the fbx imported avatar and create aniblock from imported fbx animation.
    6) Copy it to genesis 1
    7) delete the fbx import
    8) Bake genesis 1 aniblock to timeline
    9) Save as Pose Preset (make sure to chose Animation Range)
    10) Open a new scene in Daz
    11) Load up Genesis 8
    12) Make sure you have this installed: https://www.daz3d.com/forums/discussion/176806/g3f-to-g8f-pose-helper
    13) Apply G3F Pose Helper morph to 100%
    14) Drag the .duf file on top of Genesis 8.
    15) Be happy that you found an easy way to make G8 work with mixamo.
    Doesn't help seeing that the link is dead for the most important file!
    well I made one as I said, you put it in your drive:\My Library\Data\DAZ 3D\Genesis 8\Male\Morphs\-\Product or the female one, as a pose works on both and it will be a pose parameter like agent unawares one
    Ahh sorry - shoulda read your response first.
  • Leonides02Leonides02 Posts: 1,379
    My mind just exploded. What a discovery!!!!
  • takezo_3001takezo_3001 Posts: 2,027
    edited June 2018
    2) Open up Daz3D
    Thanks for making/posting this! Love your youtube channel, I'm a big fan!
    2) Open up Daz3D
    Try the Agent Unawares Pose utility (see his/her signature above).
    Downloading this as well, thanks both of you for your patience with my irritation!
    Post edited by takezo_3001 on
  • th3Digit said:
    I do use the latest DS beta if that could be a factor
    otherwise
    simply load genesis
    genesis 1
    not 2
    use an aniblock and bake it to the timeline
    save it under file save as pose animated
    load that on genesis 3
    premade genesis poses also work on genesis 3 but hands can be funny
    also if you wish for genesis 8, pose it arms up 45° legs in 6° and with the little bowtie icon tool selected, the rigging tool right click in scene edit bake joint rotations and then it too can load those saved duf poses
    you need to do this every time you load genesis 8 though, using 3 much simpler
    It doesn't work for me, how do you bake the animate to the timeline, everytime I save/reload the animation info is not there!
  • I wish someone would make a short video showing this. One that talks and explains with no music. I'm sorry but I am having trouble getting this to work. Come on @Ivy. I just bought your animation videos and you seem very good at explaining stuff
  • wolf359wolf359 Posts: 3,936
    edited September 2018
    After you have your aniblock loaded and it is  making your character move/animate, in the animate 2 tab right click choose "bake to studio keyframes"
    Follow the instructions in the attached image.
    have fun.
    800 x 2405 - 926K
    Post edited by wolf359 on
  • @wolf359, Thanks for this
  • kwanniekwannie Posts: 870
    @wolf
    Do you find that you have the infamaous G3 foot sliding when you use this technique? I tried several times and get a lot of feet sliding. I'm wondering if turning off IK has any effect on it. Thanks!
    have fun.
    And I will! Thanks so much for the mini-tut!
    EDIT: YES, it WORKS! Thanks to both of you!
  • Thanks alot for sharing!!!
    Anyone have an idea where i get Genesis 1? I cant find it in my DIM
    Genesis Starter Essentials - it doesn't have a 1 since there was, at the time, nothing from which to distinguish it.
  • philippriesphilippries Posts: 2
    edited November 2018
    Got it! cool thanks mate!
    I put the Tpose file as mentioned from Wendy_Carrara but i cant find it in my pose controls. And if i click the file via the content libary - nothing happens. Any idea?
    Post edited by philippries on
    Sorry to necro -- This works pretty well, but the arms are screwy on the G3 figure and not my G1 animation.
    Did anyone else have this issue?
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,298
    yes I have
    I don't know why, static poses work but animations can be iffy and I think its a tweening issue depending on the joint rotations
    iClone 3DX exports work better than converted aniblocks so its something in the animation itself
    Hm. I also havce the issue with Mixamo mocap.
    I wonder if it's because the T-pose for G1 is slightly different?
    Indeed this likely why this G1-G3 process works so flawlessly  in my pipeline
    I am only using Iclone motion data that has been perfectly retargeted to
    G1 in Iclone.
    I cant really vouch for  disparate Motion Data applied to G1 from elsewhere
    So  yes YMMV.
  • EightiesIsEnoughEightiesIsEnough Posts: 1,243
    edited March 2019
    I am considering purchasing some Genesis 2 animations (aniBlocks) on Renderosity in the coming weeks, and I am wondering if there is a pose helper add-on that can allow me to convert Genesis 2 animations to the Genesis 3 versions?
    I understand that it is a good idea to bake the aniBlock frames to key frames, but I am wondering if it is possible to convert Genesis 2 animations to the Genesis 3 version, with or without the add-on?
    Or, would I have to convert Genesis 2 to Genesis 1 first, and then convert the Genesis 1 to Genesis 3?
    Also, I tried a Genesis 8 animation on a Genesis 3 figure.  It seems to work no problem.
    Post edited by EightiesIsEnough on
  • I found a Genesis 2 to Genesis 3 Pose Converter add-on in the DAZ Shop, and it is added to my wishlist.
    However, I did find some animations that are for the original Genesis only.  Is there any pose converter add-on for converting Genesis poses to the Genesis 2 versions?
    Why do you want to go to genesis 2 when if baked on genesis 1 it will work out the box on genesis 3?
  • Thanks for clarifying, but I did find this out already since I made my last post in this thread, and I couldn't delete that post for some reason.
    I have to admit, I never would have thought Genesis 1 animation would work on Genesis 3 as well.  Though from what I gather, I assumed Genesis 1 animations would not work on Genesis 2.
    they work on 2 as well
    2 won't work on 3 or Micheal, Victoria 1,2,3,4 etc but all of those work on genesis with some foot adjustment needed
  • FirePro9FirePro9 Posts: 456
    edited March 2019
    G1 will work on G2 but I find it useful & better to use the DAZ store animation converter to go from G2 to G3.  Then with G3, fix the T-pose and you can go to G8.
    https://www.daz3d.com/animation-conversion-genesis-2-to-genesis-3
    Post edited by FirePro9 on
    Would like to mske all my animates purchases ready for use in carrara
    2) Open up Daz3D
    I just realized my iphone doesnt shiw sig lines
    Wsnt use the v4 thriller dance on everybody. Including frogkin
    LOL it’s an easier way to spend your money and doing something in two steps instead of one yes! devil
    ...and does not work on the G3 Male. some of us actually use males in our animated stories
  • IvyIvy Posts: 7,165
    yup and some of us like to animate animals with men..lol
    I used genesis8 male not much of a part though.
  • RobinsonRobinson Posts: 751
    2) Open up Daz3D
    For me step 5 was a failure.  I mean it worked by it introduced some pretty nasty foot-sliding all over the place.  It's pretty much unusable for me.
