Realistic Renders... NOT!! 12 "And we're back in the room!"
1272830323350
  • RogerbeeRogerbee Posts: 4,460
    I get the feeling that journey won't end well!
    CHEERS!
  • MotoTsumeMotoTsume Posts: 520
    Michael 4
    1200 x 675 - 63K
  • kyoto kidkyoto kid Posts: 41,866
    edited July 2013
    ...well, you won't see much new stuff from me for a few days as my monitor just croaked. New one should arrive by Wednesday (hopefully).
    Post edited by kyoto kid on
    m4 ironman
    936 x 1200 - 308K
  • BobvanBobvan Posts: 2,653
    edited July 2013
    Kyoto you have the worse puter luck. Hope it all works out..Roger no it don't here is one from the 1st story the rest dont suit this site http://bobvan.deviantart.com/art/Terrace-maids-7-381294750
    800 x 426 - 264K
    Post edited by Bobvan on
    1024 x 545 - 364K
    800 x 426 - 163K
    MotoTsume said:
    Michael 4
    Pretty cool, did you autofit the uniform?
    Michael 6 can't be far off, how time flies!
    CHEERS!
  • RarethRareth Posts: 1,462
    Rogerbee said:
    Rareth said:
    well its not a Lux render,
    this is just messing around with the new Base SS shader in DAZ 4.6
    Looks good,
    How did you get one with the SS shader and how did you set it up?
    CHEERS!
    There is a new base SSS shader that comes with DAZ 4.6 might be a separate download/install in DIM,
    the figure is a combination of M5 and Mr. Hyde.. the Mr. Hyde mats are used for the initial setup,
    I then changed the shader (keeping the textures) to the new subsurface base shader for all skin surfaces (excludeing finger and toe nails, eyes and stuff inside the mouth.
    there are several presets for SSS material type, I set it to skin A then tweaked it from there..
    a PDF manual comes with the shader
    Oh no!
    It never rains...
    Hope you're back in action soon.
    CHEERS!
    MotoTsume said:
    m4 ironman
    Pretty cool,
    Where did you get the gear from?
    CHEERS!
    Rareth said:
    Looks good,
    CHEERS!
    Oh, right, I've got that and I read the manual. I set mine to skin too. I didn't really have much to compare it to. Male M3dia will probably do a character that uses it so I'll steal their presets.
    CHEERS!
    Nice stuff as always Bob!
    CHEERS!
    Rogerbee said:
    Rareth said:
    Looks good,
    CHEERS!
    CHEERS!
    it does require some tweaking and a lot of test renders.
    Very true,
    I only did what I did as I was curious to see what V6 looked like.
    CHEERS!
    edited July 2013
    ok I did some more test renders (not the most flattering camera angle, and I have the HARDEST time getting the eyes to look properly at the camera. )
    here we have the same scene, same shaders/textures, one with the SSS ON the other with the SSS off (based on shader settings.)
    Top picture is SSS ON, bottom is SSS OFF
    1024 x 768 - 335K
    1024 x 768 - 337K
    Post edited by Rareth on
    There's definitely a difference. Do you think it's any better than the HSS, UberSurface or Interjection?
    CHEERS!
    CHEERS!
    I don't think I've used interjection, and I definitely like this better than HSS as for UberSurface I was never a big fan of it.
    render times do not take a huge hit when using this shader.
    The Star Trek uniform is available at sharecg and is for Valiant for m4 and courages for V4 so no need to fit.
    the ironman suit for m4 is available here: http://inlitestudio.com/3d/ , and is free.
    edited July 2013
    A little glossyish on the skin but nice renders Rareth more vore!!!! http://bobvan.deviantart.com/art/Island-336-382019372
    800 x 426 - 228K
    Rareth said:
    CHEERS!
    I see, I'll have to have more of a go sometime.
    CHEERS!
    Thanks,
    I'll grab that Iron Man suit and have a play. I used to use Starship Crew for MOS Invasion when i wanted anything Trek like.
    CHEERS!
    800 x 426 - 264K
    Thanks,
    CHEERS!
    Nice site!
    I grabbed Supes and Spidey too!
    CHEERS!
    Bobvan said:
    Hopefully she has a knife up her skirt and will cut her way out.
    CHEERS!
    Mila Kunis - using PD-Nina mat and Cd2011 Mila morph he made for me for step4
    936 x 1200 - 162K
    ...well back in business. Arrived yesterday, setup this morning. Looks really good.
    Here is a second Mila render
    927 x 1200 - 200K
    edited July 2013
    Trying to teach myself lighting with latex. The face is horribly unrealistic, need to use a different skin.
    The massive head/facemask is by ChrisT, the corset is from the Roxana Yargowhatever chick, the boots are OTK, and the entire thing is shaded with Fisty's Hardcore latex shaders. The main 'bodysuit' is actually Genesis' body itself textured with a latex shader. Lights: IG Photostudio (backdrop too) and a UE2 sphere. Pose is by Laticis in his Watchers Fall pack (modified to bring the head up).
    500 x 1000 - 295K
    Post edited by Lissa_xyz on
    more playing around with SSS shaders
    This is a scene I did previously, I used the !Subsurface Base Shader that was a freebie with DAZ 4.6 on the skin this time around,
    oh and changed the backdrop to something less busy.
    1024 x 768 - 320K
