Sharp edges smooth geometry
Jim_1831252Jim_1831252 Posts: 728
edited June 2012 in Hexagon Discussion
I’ve been running here there and everywhere looking for a tutorial I saw once but to no avail, so I’m turning to the Hex gurus here on the forums.
Now, I am fairly sure there is a way to use the smoothing tool to create extra geometry to create nice smooth curves, while at the same time keeping nice sharp edges. Am I correct? If correct, how do I keep those outside edges nice and sharp. I’m including example image in case my descriptions of the problem are falling short.
I'm looking to smooth the faces between the outside edges, which need to remain sharp.
Post edited by Jim_1831252 on
  • m_m_italym_m_italy Posts: 397
    Seleziona linee.
    Ciao.
    1410 x 818 - 204K
    Sorry.....
    1351 x 779 - 192K
  • Jim_1831252Jim_1831252 Posts: 728
    Applying the smoothing tool is not the issue, but thanks for responding. The problem is keeping the edges at the ends sharp. I remember watching a tutorial and something about folding edges was mentioned. I don't remember what tool was used, or what the process was.
    Sorry.
    Non capisco.
    Sorry.
    Ciao
    1220 x 858 - 190K
    edited June 2012
    That's the one. Many thanks ;) Oh, and I see what you meant by your first images too. That icon doesn't always show, and I'm not sure why yet.
  • edited June 2012
    It appears when you have uncollapsed geometry (look in the lower right corner at his "dynamic geometry" box).
    Post edited by emfederin_9bc0c524c8 on
    I see. So it has to be applied at the same time as the smoothing mod. Thanks
  • edited December 1969
