Adding to Cart…
billyben_0077a25354: Looking at your last log posting, the preset loaded just fine. Did you open the Puppeteer tab after you used the preset? I've tried both presets, and they work just fine for me.
Uh, issue solved. It was, wait for it, wait for it, OPERATOR ERROR DOH! Thanks for a great product.
Busted my budget to buy it. Because your products are worth it. For some reason, never got this for G3. Not sure why. Looking forward to Growing Up and the Aging Morphs. Thanks a lot.
Snagged it, that and the bend morphs as well! Thanks for this Zev0!
Thanks for the support. Enjoy:)
A question - I have a Gen8, and have changed the breasts etc. When I use the breast control puppeteer for the G8 female (fist icon in your bundle) and hit one of the arrows on the control panel that pop up for movement, my changes to the breasts disappear.
Is this because I might have used another morph than yours to alter the breasts? Otherwise, it seems to work fine with the movement.
The thing is though, your products are on such a different playing field than the others that I don't get their products, even if they're out weeks ahead of yours. I'd rather wait and get your awesomeness than get in a hurry... because a hurried product is a sloppy product in most cases.
I have that same error, I just bought the product and I'm new to daz studio but I can't reshape the breasts or glutes but i can control the bend. How did you resolve this ?
Hi,
i want to start modelling good looking women on daz3d, i came up to your bundle and
https://www.daz3d.com/genesis-8-female-body-morphs
For breasts and glutes, whats the difference with your package? who does a better job at what , thanks!
how do I get the small box with the four arrows in it to apear in Daz studio ?? I can load the breast morphs and in pose and animate there is a large set of sliders that apear in posing... I click on gen 8 female and load Breast control and it apears for a split secound and is gone..
What box with four arrows?
The preset won't open the pane (as far as I know), that is doen with Window>Pane(Tabs)>Puppeteer
Ah, well I hadn't seen your reply before mine.
Hi, how can I realise something like this? I have a pose she is lying on her back. Which morphs could I use?
Hi. Skip to 1:20 of this vid.
I used the puppeteer addon which drives the pose control morphs in the product. But if you want to manually do it, I added a screenshot of the used morph values.
Thank you very much!
Hi,
I purchased the Shape Shift Bundle for Genesis 8 Male *& Female - and the Glute Control Genesis 8. I am using Daz3D 4.10 Pro. I am having a problem using the Glute Control. I loaded the puppeteer as indicated in your blog and then double clicked the Glute Control Puppeteer. A "Readig Asset"popup appears and then nothing happens. I watched your video for the Glute Control Genesis 3 and found thaat Glute section is not under the Parameters tab. There is a Glutes section under Shaping, but no individual contrls for left and right glutes. I would appreciate any guidance on how to get your products working. Is there a manual?
Thanks.
Hello :) :) .... thank you so much for your amazing work ! ... I'm not used to the forum ( sorry if I ask a question you've answered yet !!) .... I would like to know if your are going to make a " Glute Controle movement" for male ( gen3 or gen 8 ) , or if ever , the female version can be " utility transfered" on male gen ? thank you very much.
Hello there! I purchased the Breast and Glute bundle a little while ago and I'm impressed with the breast portion of it. Nice job! I do have a problem though. I installed the bundle through the install manager as you should, and it seemed to install just fine, but when I went to try to edit the glute pieces of my G8F models, the morph setting aren't appearing in the Shapes tab. Is it supposed to be like that? I can't use the glute functions at all on my characters. I looked in the Content Library tab and it's there and it's showing in puppeteer. I tried uninstalling the product and re installing it hoping it would show up, but nothing. Is this the way it was designed? Can I try to install the morphs manually? If so, how? I can't shape or control my figure's ends like I hoped. Any advice would be helpful. Thanks for listening.
Hi. Glute morphs are under Pose Controls/Hip/Glute Control/
I'm still not seeing it.
I clicked Posing(couldn't find Pose Controls)/Hips and there's just Rotation/ Translation, and Scale.
Pose Controls are in the Parameters pane, when you have the figure itself selected.
Found it! Thank you so much! Why was it made so hard to find? Wouldn't putting them under Shaping/Waist be a much better option? Breast control is in Shaping/Chest.
I don't have this product yet, but I would guess that there are controls for the breasts under Pose Controls as well. The reason is (and again, this is just speculation) that Breast Control contains both shaping and posing controls, whereas Glute Controls is just for posing.
edit: actually, looking at the product page for Glute Control, it looks like there should be morphs as well as posing controls.
Hi Guys. G8F version has been updated with some minor tweaks. If you did a manual install please remove all files before using this version as some of the hidden morph names have been renamed and if you just overwrite you will have duplicate function morphs. Thanks.
Thanks. Good to know. DAZ product summary doesn't show this update, but see it in my DIM.
Is it just naming, or will something work noticeably differently?
