Glute and Breast Control Genesis 8 (Commercial)
135
  • nightwolf1982nightwolf1982 Posts: 1,335
    edited August 2017
    billyben_0077a25354:  Looking at your last log posting, the preset loaded just fine.  Did you open the Puppeteer tab after you used the preset?  I've tried both presets, and they work just fine for me.
    Post edited by nightwolf1982 on
  • Zev0 said:
    Thanks. I am curious to know what the issue is. Let me know.
    Uh, issue solved.  It was, wait for it, wait for it, OPERATOR ERROR DOH!  Thanks for a great product.
  • nobody1954nobody1954 Posts: 933
    Busted my budget to buy it. Because your products are worth it. For some reason, never got this for G3. Not sure why. Looking forward to Growing Up and the Aging Morphs. Thanks a lot.
  • takezo_3001takezo_3001 Posts: 2,044
    Snagged it, that and the bend morphs as well! Thanks for this Zev0!
  • Zev0Zev0 Posts: 7,123
    edited August 2017
    Thanks for the support. Enjoy:)
    Post edited by Zev0 on
  • A question - I have a Gen8, and have changed the breasts etc. When I use the breast control puppeteer for the G8 female (fist icon in your bundle) and hit one of the arrows on the control panel that pop up for movement, my changes to the breasts disappear.
    Is this because I might have used another morph than yours to alter the breasts? Otherwise, it seems to work fine with the movement.
  • WholfeWholfe Posts: 8
    Zev0 said:
    "G8 has a form of pose control for Breasts built in"
    So did G3, and the bone movement alone was not good enough on its own.
    Bend Control is done. Promos just needs finishing up. I looked at the Upper body and Daz added some new Jcm's for G8 which fixed some things so I stuck to the formula of focusing on the legs. If I decide to work on upper body then I will have to delay the Bend Control, but it is something I will look at. Glute and Breast Control was pushed forward, well because everybody likes to release those type of products first, and if I delay mine too long, by the time my set comes out, will be less appealing to buyers. There already has been countless variation products released on multiple sites.cheekyThis time around with G8, looks like a lot of people are jumping onto the type of products I make, and releasing them a lot faster than I can keep up with lol, so I no longer have the luxury of taking my time with certain IP's. Good thing about that is I will have more time for new IP's that never saw the light of day if I get things out sooner:)
    The thing is though, your products are on such a different playing field than the others that I don't get their products, even if they're out weeks ahead of yours.  I'd rather wait and get your awesomeness than get in a hurry... because a hurried product is a sloppy product in most cases.
  • Zev0 said:
    Zev0 said:
    Did you open the Puppeteer pane first?
    No, but I just did this morning.  Received the following error (see attached image).  Then I loaded G8 into the view pane selected her and tried to load Puppeter support again and still no puppeteer window.
    The log file is too long to post here.  I attached it as a .txt file.
    I think I know what it is. Try this. Make sure Genesis 8 is loaded in scene first before opening the pane and applying the preset.
    I was doing that and it did not work.  I just updated to 4.9.4.122 Pro edition and it still does not work.  I open DS.  I load Genesis 8 female.  I double click on the breast control puppeteer support icon and get an error because G8 is not selected.  I click on Genesis 8 to select her and double click on the puppeteer support icon again and the load box flashes for less than a second and no puppeteer window come up.  Same thing with G8 Glute Control and G3 Breast control.  I'm stumped.  It has to be something with my system settings as it seems that no one else is having this issue.
    Here are the last few lines if the log file after I cleared the scene and loaded Victoria 8 then clicked on the Puppeteer support Control Icon again.
    2017-08-15 19:11:57.629 *** Scene Cleared ***
    2017-08-15 19:12:12.667 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:12.670 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:12.670 WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB
    2017-08-15 19:12:12.672 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:12.674 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:12.675 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:12.678 WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB
    2017-08-15 19:12:12.684 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:12.719 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:12.719 WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB
    2017-08-15 19:12:12.720 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:12.720 WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB
    2017-08-15 19:12:12.721 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:12.724 WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB
    2017-08-15 19:12:22.177 *** Scene Cleared ***
    2017-08-15 19:12:24.201 Begin Loading Character Addons...
    2017-08-15 19:12:24.293 File loaded in 0 min 0.0 sec.
    2017-08-15 19:12:24.294 Loaded file: Genesis 8 Female Eyelashes.duf
    2017-08-15 19:12:24.326 Loaded Morph Deltas in 0 min 0.0 sec.
    2017-08-15 19:12:24.361 Loaded Morph Deltas in 0 min 0.0 sec.
    2017-08-15 19:12:24.361 Loaded file: FBMVictoria8.dsf
    2017-08-15 19:12:24.363 Loaded file: FHMVictoria8.dsf
    2017-08-15 19:12:24.367 Loaded Morph Deltas in 0 min 0.0 sec.
    2017-08-15 19:12:24.368 Loaded file: PHMMouthRealism_HD_div2.dsf
    2017-08-15 19:12:24.393 Loaded Morph Deltas in 0 min 0.0 sec.
    2017-08-15 19:12:24.393 Loaded file: PBMNavel.dsf
    2017-08-15 19:12:24.404 Loaded Morph Deltas in 0 min 0.0 sec.
    2017-08-15 19:12:24.404 Loaded file: PHMEyelashesExpand.dsf
    2017-08-15 19:12:24.534 File loaded in 0 min 0.0 sec.
    2017-08-15 19:12:24.535 Loaded file: Victoria 8 Eyelashes.duf
    2017-08-15 19:12:24.537 Finished Loading Character Addons
    2017-08-15 19:12:24.545 File loaded in 0 min 2.3 sec.
    2017-08-15 19:12:24.568 Loaded file: Victoria 8.duf
    2017-08-15 19:12:25.111 Loaded image Victoria8LegsD_1003.jpg
    2017-08-15 19:12:25.183 Loaded image Victoria8EyesD_1006.jpg
    2017-08-15 19:12:25.376 Loaded image Victoria8ArmsD_1004.jpg
    2017-08-15 19:12:25.445 Loaded image Victoria8MouthD_1005.jpg
    2017-08-15 19:12:25.658 Loaded image Victoria8FaceD_1001.jpg
    2017-08-15 19:12:25.852 Loaded image Victoria8TorsoD_1002.jpg
    2017-08-15 19:12:25.915 Loaded image Victoria8Eyelashes_1001.jpg
    2017-08-15 19:12:29.692 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:29.694 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:35.397 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:35.397 WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB
    2017-08-15 19:12:35.398 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:35.398 WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB
    2017-08-15 19:12:38.980 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:38.983 WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB
    2017-08-15 19:12:38.984 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-15 19:12:38.984 WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB
    2017-08-15 19:12:41.732 File loaded in 0 min 0.1 sec.
    2017-08-15 19:12:41.732 Loaded file: Breast Control Puppeteer Genesis 8 Female.duf
    I have that same error, I just bought the product and I'm new to daz studio but I can't reshape the breasts or glutes but i can control the bend. How did you resolve this ?
  • Hi,
    i want to start modelling good looking women on daz3d, i came up to your bundle and
    https://www.daz3d.com/genesis-8-female-body-morphs
    For breasts and glutes, whats the difference with your package? who does a better job at what , thanks!
  • prinzeugenprinzeugen Posts: 40
    how do I get the small box with the four arrows in it to apear in Daz studio ?? I can load the breast morphs and in pose and animate there is a large set of sliders that apear in posing... I click on gen 8 female and load Breast control and it apears for a split secound and is gone..
    Did you open the Puppeteer tab? After that click on the Breast Control puppeteer preset and the preset will load inside puppeteer.
  • Richard HaseltineRichard Haseltine Posts: 111,840
    What box with four arrows?
    The puppeteer preset.
    The preset won't open the pane (as far as I know), that is doen with Window>Pane(Tabs)>Puppeteer
    edited May 2018
    Yes I know that. Thought you were asking what the preset looks like lol
    Ah, well I hadn't seen your reply before mine.
  • JUJUJUJU Posts: 1,133
    edited July 2018
    Hi, how can I realise something like this? I have a pose she is lying on her back. Which morphs could I use?
    Post edited by Chohole on
    edited July 2018
    Hi. Skip to 1:20 of this vid.
    I used the puppeteer addon which drives the pose control morphs in the product. But if you want to manually do it, I added a screenshot of the used morph values.
    1564 x 812 - 1M
    Thank you very much!
  • Hi,
    I purchased the Shape Shift Bundle for Genesis 8 Male *& Female - and the Glute Control Genesis 8.  I am using Daz3D 4.10 Pro.  I am having a problem using the Glute Control.  I loaded the puppeteer as indicated in your blog and then double clicked the Glute Control Puppeteer. A "Readig Asset"popup appears and then nothing happens.  I watched your video for the Glute Control Genesis 3 and found thaat Glute section is not under the Parameters tab.  There is a Glutes section under Shaping, but no individual contrls for left and right glutes.  I would appreciate any guidance on how to get your products working.  Is there a manual?
    Thanks.
  • maxminskmoussardmaxminskmoussard Posts: 6
    edited October 2019
    Zev0 said:
    Hi Guys. Just a heads up these are basically finished. Will be separate offerings as well as a bundle option. Breast Control will also have puppeteer support built in and wont be a seperate product. Glute Control will now be a merchant resource as well.
    Hello :) :) .... thank you so much for your amazing work ! ... I'm not used to the forum ( sorry if I ask a question you've answered yet !!)  .... I would like to know if your are going to make a " Glute Controle movement" for male ( gen3 or gen 8 ) , or if ever , the female version can be " utility transfered" on male gen ? thank you very much.
  • Hello there! I purchased the Breast and Glute bundle a little while ago and I'm impressed with the breast portion of it. Nice job! I do have a problem though. I installed the bundle through the install manager as you should, and it seemed to install just fine, but when I went to try to edit the glute pieces of my G8F models, the morph setting aren't appearing in the Shapes tab. Is it supposed to be like that? I can't use the glute functions at all on my characters. I looked in the Content Library tab and it's there and it's showing in puppeteer. I tried uninstalling the product and re installing it hoping it would show up, but nothing. Is this the way it was designed? Can I try to install the morphs manually? If so, how? I can't shape or control my figure's ends like I hoped. Any advice would be helpful. Thanks for listening.
    edited October 2019
    Hi. Glute morphs are under Pose Controls/Hip/Glute Control/
  • I'm still not seeing it.
  • I clicked Posing(couldn't find Pose Controls)/Hips and there's just Rotation/ Translation, and Scale.
  • GordigGordig Posts: 10,821
    Pose Controls are in the Parameters pane, when you have the figure itself selected.
  • Found it! Thank you so much! Why was it made so hard to find? Wouldn't putting them under Shaping/Waist be a much better option? Breast control is in Shaping/Chest.
    edited October 2019
    I don't have this product yet, but I would guess that there are controls for the breasts under Pose Controls as well. The reason is (and again, this is just speculation) that Breast Control contains both shaping and posing controls, whereas Glute Controls is just for posing.
    edit: actually, looking at the product page for Glute Control, it looks like there should be morphs as well as posing controls.
    Post edited by Gordig on
    Hi Guys. G8F version has been updated with some minor tweaks. If you did a manual install please remove all files before using this version as some of the hidden morph names have been renamed and if you just overwrite you will have duplicate function morphs. Thanks.
  • Thanks.  Good to know.  DAZ product summary doesn't show this update, but see it in my DIM.
    Is it just naming, or will something work noticeably differently?
