New Stuff Not Showing in Smart Content or Database
2»
  • dan.shivedan.shive Posts: 0
    I *THINK* all my stuff is fixed now. When I first deleted the existing database, I also deleted the folder it was contained in. I'm not certain, but there's evidence to suggest that this is why it didn't work quite right the second time around. Third time's the charm? So far? Maybe it will stay that way? *fingers crossed*
  • visiblemanvisibleman Posts: 178
    Lindsey said:
    Mentioned earlier, there is a Start and Stop icons in your Start Menu>All Programs>DAZ 3D>DAZ Content Management Service
    OK!
    I Started Content Management and now I'm Re Importing the MetaData.
  • LindseyLindsey Posts: 2,015
    Sounds like you two are on the right track... !
    edited February 2013
    Just a note if you see missing product icons in Smart Content. What I'm finding is in the metadata .dsx file in Runtime\Support there is a line that points to the products' .dsx file name. I'm finding 9 times out of 10 there is either a typo in the .dsx file name, or the path to the .dsx file is wrong. If you fix it in a text editor, save and re-import the metadata the icons will show up.
    Post edited by Lindsey on
    Yeah...its taking a while but so far...it looks like its doing its job.
    Thank you Very Much LINDSEY!
    It's all working like its suppose to.
    Now I can FINALLY...Go to bed.
    LOL!
    Thank you again and to everyone that helped.
    peace.
  • Okay, it sounds like there are several different problems people are having.
    If you have some Smart Content and Categories but can't add anything new, that sounds like database corruption. In DS4.5 you can export User Data to save your existing custom categories, then reset the database and reimport them.
    If you have Smart Content but can't load anything from it, that could mean your content folders aren't defined correctly. If you go to Edit > Preferences > Content Library > Content Directory Manager, expand the "DS format" and "Poser format" sections, and post a screen shot, we can try to sort out the problem.
    Fixing Daz studio format by editing my library path to non-default path I'm using fixed the issue, thanks alot
