Hexagon tessellation options ?
is there another way to tessellate? because I get nowhere with Catmull-Clark and it looks ugly
  • AscaniaAscania Posts: 1,858
    edited April 2018
    Smoothing in the Surface Modelling tab. And what do you consider ugly there?
    Post edited by Ascania on
    The chamfer algorithm is not as nice as the Catmull-Clark algorithm, unfortunately. It's hard to get good reflective surfaces without noise from chamfering.
    apart from the limitations, I would like to be able to straighten the edges in a way so that they remain as paralel as possible (I'm not sure if retopo can do that in another program like Modo)
    the reason is I have a mesh where I need to extrude the faces all around as shown in the screenshot but they are not paralel
    QUOTE: The chamfer algorithm is not as nice as the Catmull-Clark algorithm, unfortunately. It's hard to get good reflective surfaces without noise from chamfering.
    yep, another issue that drives me against the seiling - on a side note this is not a problem in Blender or at least I never had an issue in Blender but I still don't like Blender modeling workflow and prefer Hexagon
    would be nice if someone comes up with an idea because I have no idea what to do
    edited May 2018
    The tesselation is more concerned with staying faithful to the geometry and maths of the operation than to look good to the user.
    Try instead slicing your chamfered object and then retopo it along those slices. Takes more work but that's the best Hex can do.
