3D World Says DAZ Plans for Generation 6 in 2013 [UPDATE] Well, now it's here!
1457910
  • zigraphixzigraphix Posts: 2,787
    barbult said:
    When they released DAZ Horse 2, I thought your cow was just around the corner. But sadly not, I guess. G2/V6 must have chased it off.
    I thought the same! I'm really hoping we get more quadruped shapes out of Horse 2. More ungulates, please! (and not just toy cartoon ungulates, though those were cute, in a slightly creepy way....)
  • RorrKonnRorrKonn Posts: 509
    Xena said:
    RorrKonn said:
    Anyways I discovered that Genesis was not symmetrical .
    Perhaps Daz did it on purpose? Everyone always says they want more realism in their characters ... humans aren't symmetrical so wouldn't it make sense for a 'realistic' character like Genesis to be asymmetrical? (:
    where talking about the topology.not the looks of the mesh.
    Genesis is symmetrical and symmetry works in zbrush, I use it all the time. Are you trying to use symmetry on a posed character in asymmetrical pose, rather than the default TPose?
    yes
    yes
    Zbrush doesn't work that way. Use the default zeroed t-pose so that zbrush can calculate the symmetry.
    Think of it this way. How can zbrush calculate the center of a model if it's twisted and contorted? It can't.
    Genesis is symmetrical and Zbrush can use symmetry if you import it zeroed.
    Have to give cridit to AmbientShade for the info.
    latest up date.
    took M5 to C4D
    didn't see anything wrong with the mesh or forearms.
    then export .obj
    I got M5's skin to work in Z with Pose symmetry.
    but Not the eys n mouth teeth n toung thou.
    So I think the not symmetrical part
    is some where around the eyes ,eyelashes ,mouth ,teeth, toung.
    haven't track down the exact part.
    edited June 2013
    latest up date.
    took M5 to C4D
    then export .obj
    I work with M5 especially a lot and take it into both and modo (which is extremely picky about symmetry)... M5 is symmetrical and Genesis is symmetrical. I would track the issue down to how you are exporting it, because that's the issue.
    Also, don't edit or export Genesis from Poser and expect it to work correctly. Genesis is not native to that program so you're just going to mess yourself up and have issues just like you posted.
    Export from DS, base resolution, 0 subdivisions then you should have no issues.
    Post edited by Male-M3dia on
    yes
    Transform / use posable symmerty .
    right under active symmetry
  • kyoto kidkyoto kid Posts: 42,209
    edited June 2013
    ...which is a pain in the bum. I often would introduce slight imperfections into the facial mix like one ear slightly or one eye slightly higher/lower than the other to give more character to the character. That is not possible with Genesis outside of adjusting the mesh in a modeller. In that way it is "too perfect". They need to bring back the independent left/right ear and eye transition and scale controls.
    Post edited by kyoto kid on
    edited June 2013
    RorrKonn said:
    yes
    Import your figure zeroed, in T-pose and it will work correctly. Once again, that's not how zbrush works.
    Also, don’t edit or export Genesis from Poser and expect it to work correctly. Genesis is not native to that program so you’re just going to mess yourself up and have issues just like you posted.
    It's really up to you whether you want to do it correctly or spin your wheels posting things that won't work.
    was just using .obj for testing.
    I use GoZ.
    I use GoZ.
    And if you are doing it from Poser, that's why you are having the issues. The DSON Importer is just that... an importer so you can pose, clothe and render... not do content development because those tools aren't compatible with Genesis.
    Export from DS and it will work.
    edited June 2013
    I use GoZ.
    I do not have DSON .Don't use Genesis in Poser.So I GoZ Genesis from DAZ Studio to zBrush.
    Transform / use posable symmerty .will not work with genesis
    Post edited by RorrKonn on
    edited June 2013
    RorrKonn said:
    I use GoZ.
    Still you are importing incorrectly. With all the genesis characters I've made and sold using zbrush for the last two years, I would have noticed by now if Genesis has symmetry issues and others would have too.
    Export zeroed, t-pose... base resolution, 0 subdivisions... import into zbrush, press 'x' to activate symmetry.... you'll see the two red cursors showing you now have symmetry activated and start to morph.
    t-pose activate symmetry.works fine don't mean that there's not a flaw that needs fixed
    Does Transform / use posable symmerty work for you with genesis ?
    Seconded. Can I hear a thirded? Way too many useful V4/M4/etc minor tweak morphs just never existed in Genesis or the major DAZ-supplied morph expansion packs.
    Did you press x then that option? You only need to press the 'x'... the option you want is when you want to pose Genesis while modifying the mesh with symmetry... which then you can't import back into genesis as a morph target correctly as now you have to adjust the rig for what you posed in your morph.
    I'm not making morphs for Genesis.
    next update
    genesis out side skin mesh polycount 14918, top and bottom gums works with zBrush transform / use posable symmerty.
    teeth do not
    all the stuff around the eyes don't
    haven't broken all that down to pinpoint why.
  • HeraHera Posts: 1,962
    [Way too many useful V4/M4/etc minor tweak morphs just never existed in Genesis or the major DAZ-supplied morph expansion packs.
    Hear hear!
    I miss the possibility to remove the fingernails, which worked with the G4 people. Without that function second skin gloves become useless!
  • scorpioscorpio Posts: 8,533
    Hear hear!
    One of the first things released for Genesis.
    http://www.daz3d.com/monster-details-for-genesis
  • BarubaryBarubary Posts: 1,232
    Even IF it turns out to be incompatible, I am sure there will be enough new items coming out for Genesis I for some time to come. People are still cranking out V4 stuff long after she was discontinued.
    Yeah, and they do not create clothing for Genesis, which is what kinda split the market in two. So now we're gonna split in in three? Doesn't sound like a winning formula to me.
  • LordHardDrivenLordHardDriven Posts: 937
    RorrKonn said:
    I use GoZ.
    I got to say I'm admiring your patience at trying to explain to someone who wants to "do it their way" the proper way to do things. I wish I had the patience you're displaying.
    edited June 2013
    transform / use posable symmerty .does not work with genesis even thou it should.
    so between zbrush ,goz ,genesis there's a flaw that needs fix.
  • JabbaJabba Posts: 1,461
    I do my Genesis morphing in Hexagon, which works great for me... I'm sure G2 will be every bit as good, and who knows what goodies it has that we don't know about yet (I mean extra polygons rather than genitals, not that I wouldn't mind but don't realistically expect)
  • agent unawaresagent unawares Posts: 3,513
    edited June 2013
    RorrKonn said:
    I use GoZ.
    Patience is only necessary because he's "explaining" the answer to a completely different question. All he's saying is that symmetric morphing works on a zeroed Genesis. Of course it does, and it's irrelevant. Symmetric morphing works even on completely asymmetric objects. The question was about Posable Symmetry.
    Post edited by agent unawares on
    RorrKonn said:
    I use GoZ.
    Right, and as that's fine if he wants to make a sculpture; but if he tries to import it back after posing it, it's no longer zeroed and won't work. So even going this route is pretty useless if you're doing a morph for genesis.
    But I'm done helping. I wish him luck, but there's nothing to fix.
    Are They going to Rig V6 for Poser ?
    edited June 2013
    Hear hear!
    ...yes but the "Nails Gone" morph was part of the Gen4 Morphs++ expansions (which essentially are what the Evolution Body/Head Morphs are to Genesis), not the Creature Creator or any other themed morph sets. There was also a "Nails Gone" morph in the Gen3 Morphs and MATs expansions. Seems ridiculous that for Genesis, a separate themed PA resource is required (at an additional expense) to get this single morph which should have been included in the Genesis Evolution Morphs expansion.
    Several I'm not pleased that are missing include: Arms - Size, independent positioning and size morphs for eyes and ears, and more tongue control (can't even get Genesis to lick it's lips with the supplied tongue morphs which was easy to do with the Morphs++).
    The only other way to get these "missing" morphs into Genesis is to have the V4/M4 Shapes for Genesis and the Genesis Generation X plugin, a 52$ outlay (unless one is a member of the PC end even then it is only about a 6$ savings as GenX is a PA product).
  • frank0314frank0314 Posts: 14,847
    edited June 2013
    I would assume they would still use the DSON importer.
    Post edited by frank0314 on
    edited June 2013
    As the product that was accidently released prematurely did say it needed DSON, then I would say it was a given that V6 will need DSON.
    Post edited by Chohole on
