Novica & Forum Members Tips & Product Reviews Pt 10
Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
A couple of years ago, I tried my hand at dial-spinning a character and then saved her. I did something wrong, as after that the base character my dial-spin was using was loaded 100% for every single G2F I loaded. Once I figured out what was happening, I contacted support. They helped me fix the problem, which required I delete some files if I recall correctly.
The easiest way to find such an issue is to select the the figure in the Scene tab, open the Shaping tab and click on the Currently Used option. Look for a named character morph. Elliandra isn't based on another figure, so there shouldn't be any other named character dialed in. Also, Elliandra does not require either the body or head morph packs, so if there are a lot of those listed, that could be the source of the problem.
Elliandra is for both G3 and G8. Have you tried loading both generations side-by-side? If the problem I had is present here, it should only affect one of the two.
Anyway, if you discover the problem is the extra morph, I'll dig up the support ticket and share the solution with you. Either post here, or PM me.
I wish I could load a figure without every morph I've bought or downloaded being loaded in it makes it hard to find the ones I'm looking for
When you have a figure selected and open the Shaping tab, there is a text field above the right column, where the morphs are listed. You can filter the morphs by typing in what you're looking for. Need to use cornea bulge? type in "cornea," (without the quotes.) In the left column, every folder without a cornea morph will be grayed out. Click on the one that isn't gray. The morph you need will show up in the right column. If a word is used in multiple areas, (for example, you have a male figure selected and type in bulge,) you may see more than one folder highlighted. This works for any morph, so if you're looking for a specific character, type that name into the filter field. Voilà!
I haven't been able to use any search function inside DS on any machine I've owned. They just sit there and do nothing if they let me type anything in or DS just crashes and nothing shows in the log file about it
The Wild Wind Hair was updated today and the red hair works now.
The filters in the Editor tabs of property panes are not searches, as far as I know, so they shouldn't have the same problem (which sounds like an issue connecting to the CMS).
Did anyone pick up that bonus madness offer the G7 Bio Suit for G3F? https://www.daz3d.com/g7-bio-suit-for-genesis-3-females
I'm wondering about the material zones on the suit, how many there are. If it's all one, or quite a few.
I didn't pick that up. I didn't realize it was a special offer item, which is one of the problems I have with these sales- its not always clear. The large repetitive pattern on the outfit kept me from buying. I like patterns to be smaller or less repetitive. That did not appeal to me... I also tend to only use gen 8.
You'll be delighted to hear it has a lot of material zones. Let me finish a render and I'll show them off.
Elliandra that I rendered was Genesis 8 BTW. (And as I said, I clicked on the avatar in Characters, I didn't continue into the file section where you can choose different makeups, etc. It was the default load. Did you ever find out the problem in Smart Content? And which generation did you use?
Bio Suit material zones
oh fantastic!! thank you! I was thinking the blaster pistol alone was worth the $2.32 LOL but yeah, I can change the suit easily with shaders, and have emmissive lights on the the little round things!
I didn't like that repetitive pattern either, but now that agent unawares showed me the material zones, I knew I could use shaders to get rid of it. It autofits pretty good to G8F also, even the boots (given that they are flat heeled, there's usually way more success than high heels). This is Marigold G8F wearing the suit and boots. Ignore the belt - I forgot to shade it. LOL. Still grainy cos i was just quickly testing the suit, so just a quick one.
Thanks, but it's a known issue that Photoshop does not work in High Sierra. Adobe has no reason to upgrade it because they want to push CC and Apple is more interested in Apple and knows that current CC is compatible so they don't care about supporting old software...
I realized what happened... I used a body morph slider that I had created when everyone was learning how to transfer G3 morphs to G8 but I didn't know how to separate the head morph from the body so when I added the body morph it also added to the face morph. However, when I tried again, I still noticed some chiseling on the nose and in certain lighting, it is more noticible. If you look at your image above, imagine that there was more shadow and look at the top plane of the nose, it's almost flat and the sides come down a bit sharply. It's not as noticeable in your light, but even without my extra morph, there's a very chiseled nose...
Thanks L'Adair but I figured out what went wrong LOL! This is what I wrote to Novica in case you missed it...
Ah sorry I was not aware of that. Sad state of affairs
Will do, I will make something up for you this weekend (fri - Sat for me) and post it for you.
Has anyone who owns the Flamenco dress for V3 tried it with Dforce? The pants and jacket from the Matador outfit of the same vintage work okayish with Dforce (assuming you choose your poses and settings carefully), so I was curious about this one. I know from comments by, I think Llynara, that autofitting the flamenco dress forward gets kind of iffy results, but sometimes dforce can offset those problems.
This is my next render from my ten GF3 characters list.
Number six on my G3F list is FW Art Brooke. I've paired her with Pixie Bob Hair and Office Wear for Genesis 3. I changed the blouse using shaders, but otherwise everything else is standard. I think the hairstyle makes her look a little severe. Her promo images are with long hair and she has a much softer look.
1. Full Figure
2. Portrait.
SaveSave
Thanks! Much appreciated!
Nihi Sumba Cabana Everyday Fruit Cartoon Parrot for Daz Studio
To do the first render was under 7 minutes, so I will say this isn't intensive. I then added a background, zoomed in which required more details, and it was 20 minutes. I recommend Gulf Skies, sold elsewhere, for a nice variety of beaches and tropical settings, including palm trees and sunsets. I didn't blur this to provide fake DOF, normally I do but this will show you the background.
Also, this is Pro-Studio lighting, which is used for portraits. Wanted to show how these can work for outdoor.
The Toon Parrot has nice bones, you can really fine tune the wing feathers. One thing missing in the pose presets (which are adorable) are any of the bird flying. Although he is pudgy and a toon, would like to have one or two flying.
This toon bird's pose presets zip the character back to World Center. TIP: Hold CTRL when you click the pose, and uncheck all the translations. The character won't leave where you have it in the Scene.
@maclean The Everyday Fruit looks good! Our friend really appreciates it too.
Not a fan of that almost-laying-down palm tree, found it a bit much for my personal tastes. Palms do curve toward the light if deprived of the sunlight due to shade. Some species probably also curve on their own regardless. I just prefer less slope.
@Mollytabby Brooke looks good, you've got a great list going there!
One thing for those who aren't aware of it- whatever camera you use, if you select it in Scene, then over in Parameters go to Camera, the focal length for portraits optimally may be between 90-125 or so. That way you don't get nose distortion or head distortion due to the closeup. Your camera is tilted (maybe on purpose?) and you'll see the difference in the head size and the body size.
The head is bigger which suggests you may have the focal distance on 65 or whatever the default is. (and it is a nice effect, so that's why I'm saying you may have done it on purpose.
I'm not great with camera settings but we had a prolonged discussion on it and the 90-125 stuck with me and that's what I use to showcase all the portraits to avoid distortion. To give you an idea, it's 21 for the distant shot in the second render.
I love the parrot and fruit. Both look good!
One thing about the parrot- The wings from the side are very thin. You have to be very careful of the camera angle.
CS5? I'm still working with CS 4.
Bar Interior 2018
Well, it took 7 minutes and still showed 0 percent, then kicked into gear and went 4% at 8 minutes. Right now 11 minutes and still 4%. So on this one, be advised if you have a slower computer, you may struggle. It all loads as one scene. Will post back more in about 45 minutes. It is an amazing set if you can get past the render times. When it's done I will look in Scene to see how/if it's broken down and grouped for you.
Edit:
0% 7 minutes
4% 11 minutes
16% 24 minutes
19% 30 minutes
35% 2 hours 10 minutes
39% 2 hours 35 minutes
47% 3 hours
You get the idea. SLOW (my computer is fast.)
WOW 29% at 1 hour 40 minutes. Anyone else render this set? It's got to be something funky with my computer. I do have quite a few windows open.
The render at 75% is in this post
From the product page it looks like there are a lot of options
I picked it up but haven't looked at it yet
Hello,
Question .. I tried to use the buy 2 or more and get a package free sale and even putting three qualifying items in my cart, the free item wasn't free. Anyone else get this?
Not having the sale work in my cart is a great strategy to not spend money. LOL :)
EDIT: Tried a third time and it worked ... same items. WEIRD!
Welcome to the Weird World of Daz sales
