Simple WorldBalls for DAZ Studio 3/4.5+ and Poser 6+
3dcheapskate3dcheapskate Posts: 2,689
edited December 2015 in Freebies
(4th December 2015 - I've been told the "validateFormat" problem when trying to edit old posts has just been fixed, so this is just a test...)
(Full list of environment sets released so far at the bottom of this post)
A free (and probably better!) alternative for Poser if my worldball doesn't suit you - try bagginsbill's Environment Sphere (and for tips on using HDR with it see this "IBL-HDRI" Renderosity thread)
Poser WorldBall version 5 released - post #121
Simple update for anybody who has BOTH Poser AND DAZ Studio versions, and sometimes loads the wrong prop - post #119
Poser WorldBall Version 4 released - post 118
Poser worldball bug fixes WIP- post 113.
DAZ Studio worldball IBL/Sun parenting WIP - post 114
Poser IBL/Sun parenting workaround in post #105.
Preview icons to remind you what the environment sets look like - post 98/99
Helper scripts for creating your own sets - post 97
Caution on using UE2 instead of the WorldBall IBL - post #96
Tentative first steps into using HDR lighting with the WorldBall start at post #88. First environment set to include HDR lighting (as well as normal lighting, not instead of!) is E18 Alien Desert (post #94).
The WorldBall was created as a quick-and-easy way fo add a simple background to a scene without having to hunt through libraries, or worry about backdrop positioning, lighting, and camera angles. It's far from perfect, and way behind the more professional environments and skydomes, but it's good enough for the intended purpose and has it's own upstart charm! ;o) Check out some of the results at the Poser/DAZ Studio WorldBall Render Gallery thread over in the DAZ Art Studio forum (and feel free to post your own there too!)
The Simple WorldBall is available in both Poser and DAZ Studio versions. It consists of an all-encompassing sphere with a full 360° azimuth / ±90° elevation background image, a light for global illumination, another light to create the sun shadows, and a ground plane used as a shadowcatcher. There are five very simple envirponment sets included (plus one test environment).
There's a single script file to load/change the WorldBall - simply double-click the script icon. It prompts you to select from the available environment sets, and then loads the WorldBall, IBL, Sun (and Ground) with the appropriate settings. Use the same script to change the environment after you've loaded the WorldBall.
The environment data is contained in a plain text file so you can easily add additional environments.
Simple Poser WorldBall
The original Poser version is available at ShareCG or Renderosity Freestuff) (Note: The original Poser WorldBall didn't work on a MAC - Version 2 upload fixed this. Version 3 fixes the irritating 'please locate WorldBall.lt2 issue. Version 4 fixes the background not displaying in preview and possibly the light colour/intensity not updating)
The WorldBall is a Poser prop, the IBL is a Diffuse IBL light, and the sun is a distant light. The default GROUND prop is used.
The PoserPython script file is in plain text, so if you're a code-monkey feel free to play with it. It's still at the 'held together with sticky-tape and string' stage - but hey, it works! ;o)
Feedback regarding any problems you encounter would be appreciated (as would suggestions for improvements, additional environment sets, etc)
Simple DAZ Studio WorldBall
Available at ShareCG or Renderosity. (Note: The WorldBall works on DS3 and DS4.5, but NOT on the intermediate DS4.0 - I've tried, but failed, to resolve this)
IMPORTANT! SEE THE README FOR INSTALLATION DETAILS - THE SHADERBUILDER IBL MUST GO IN A VERY SPECIFIC LOCATION.There were a couple of errors in the original ReadMe (fixed in the Version 2 upload):
1) it should tell you to copy the CONTENTS of the 'Studio3/4 ShaderBuilder Light' folder, NOT the folder itself! See post #6)
2) You need to copy the appropriate 'Studio3/4 ShaderBuilder Light' if you use DAZ Studio, REGARDLESS of whether you use Poser.
The WorldBall is a Poser prop, the Ground is a DS plane primitive with a ShaderMixer material, the IBL is a ShaderBuilder light, and the sun is a simple distant light.
The DAZ Script file is in plain text, so if you're a code-monkey feel free to play with it. It's still at the 'held together with sticky-tape and string' stage - but hey, it works! ;o)
Hints On Using The WorldBall
- Do Your Figures Look Too Dark In Your DAZ Studio WorldBall Renders? post #6
- Adding Your Own Environment Sets - The ‘WorldBallData.txt’ File post #7
- A Few Tips For Adjusting The Lighting And Shadows post #13
- If you want AO from the global illumination in DAZ Studio, try using the UberEnvironment2 (free with DS3A and DS4 Pro) instead of the WorldBall IBL - post #25
- A couple more hints on how I use the WorldBall - post #68
Full List Of Environment Sets Released To Date
(All environment sets are available from ShareCG and Renderosity Freestuff. Links to post numbers are to posts later in this thread)
E00 'Test1' - included with both the Poser and DAZ Studio verisions of the WorldBall
E01-E05 'Snow/Lake/Sand/Scrub/Mars' - included with both the Poser and DAZ Studio verisions of the WorldBall
E06 'Mountain Lake 01' - post #15, post #31 - ShareCG / Renderosity Freestuff
E07 'Above The Clouds' - post #15 - ShareCG / Renderosity Freestuff
E08 'Below The Waves' - post #15 - ShareCG / Renderosity Freestuff
E09 'Swimming Pool' - post #26 - ShareCG / Renderosity Freestuff
E10 'Northern Forest' - ShareCG / Renderosity Freestuff
E11 'Misty Mountain' x 4 (the same scene in dawn, noon, evening and moonrise variants) - post #34 - ShareCG / Renderosity Freestuff
E12 'Basic Toon' x 4 (the same scene in dawn, noon, sunset and midnight variants) - post #42 - ShareCG / Renderosity Freestuff
E13 'Earth Environs' x 2 (a low earth orbit scene with earth, sun, moon, and stars plus a starfield only variant) - post #58 - ShareCG / Renderosity Freestuff
E14 'Grasslands' x 2 (the same scene in daytime and evening variants) - post #60 - ShareCG / Renderosity Freestuff
E15 'Galaxies And Nebulae' (14 galactic/nebulous Hubble images strewn unrealistically across an Earth-based starfield!) - post #66 - ShareCG / Renderosity Freestuff
E16 'Cinderside' (volcanic ash over lava) - post #67 - ShareCG / Renderosity FreeStuff
E17 'Danny's Island' a tropical paradise, with a lurking shark! - post #92 - ShareCG / Renderosity FreeStuff
E18 'Alien Desert' (lo-res background, but includes HDR lighting for Poser/DAZ Studio) - post #94 - ShareCG / Renderosity FreeStuff
E19 'Sea Dawn' - post #100 - ShareCG / Renderosity Freestuff (soon)
(I also have the original cubemap renders and vertical cross images - if anybody prefers those please contact me)
If you can't see what you're looking for in that list, I take requests, or you could...
Create Your Own 360° Azimuth / ±90° Elevation Backgrounds
Using just Terragen Classic, GIMP, and HDRShop Version 1 (all free) it's far simpler than you'd imagine! Check the "Make Your Own Environment Maps And Light Probes" PDF at ShareCG (also at Renderosity > Tutorials > Other Software).
If you picked up Bryce 7.1 Pro when it was free, then it provides a marvellous alternative to Terragen Classic. Just remember to set the render FOV to 112.5° !!! (You need to do this in order to get a 90° FOV render - for some arcane reason Bryce uses 80% of the FOV you type...) And don't forget to UNCHECK'Link Sun To View'.
Edit 31st Jan 2014: I've uploaded a couple of helper scripts to automate the two most tedious and error-prone parts of the procedure - see post 97.
Post edited by 3dcheapskate on
«1345
  • 3dcheapskate3dcheapskate Posts: 2,689
    edited June 2013
    In the preview pane you won't see much - you need to render. Here's the DAZ Studio 3 preview pane.
    405 x 405 - 54K
    edited June 2013
    To load the WorldBall or to swap environment sets you simply run the same script. These are the sort of dialogues you get in DAZ Studio 3.
    782 x 676 - 141K
    Here's a few sample renders in DAZ Studio 4.5 and DAZ Studio 3.1
    1000 x 1500 - 2M
    And here's the 5 + 1 environment sets. Note that the angular map light probe images are only in the Poser version. The DAZ Studio version uses latitude/longitude maps for the diffuse IBL.
    1536 x 768 - 321K
  • gingercakes47gingercakes47 Posts: 382
    Thank you. Will be trying this out to see how it works.
    edited June 2013
    If they do then it's likely that DAZ Studio isn't finding the WorldBall IBL ShaderBuilder file at rendertime.
    To check, load the WorldBall with the 'E01 Snow' environment, load a figure, and compare with the three renders in the attached image.
    The most likely cause of the problem is that you actually followed the instructions in the ReadMe correctly!
    I just spotted an error in the ReadMe - It should tell you to copy the CONTENTS of the 'Studio3/4 ShaderBuilder Light' folder, NOT the folder itself! E.g. for a Windows 7 / DAZ Studio 4.5 system...
    RIGHT...  C:\Users\Web\AppData\Roaming\DAZ 3D\Studio4\shaders\ShaderBuilder\Light\3DCheapskate\WorldBall IBL DS4.sdl
    WRONG!... C:\Users\Web\AppData\Roaming\DAZ 3D\Studio4\Studio4 ShaderBuilder Light\shaders\ShaderBuilder\Light\3DCheapskate\WorldBall IBL DS4.sdl
    My apologies. :red:
    800 x 800 - 153K
    Adding Your Own Environment Sets - The 'WorldBallData.txt' File
    After installing the WorldBall you should have a single WorldBallData.txt file. It's location depends on whether you use just Poser, just DAZ Studio, or both. It will be one of the following:
    \Python\poserScripts\3DCheapskate\WorldBall\WorldBallData.txt
    \Scripts\3DCheapskate\WorldBall\WorldBallData.txt
    The details for each environment set are contained in this file as a datablock like this:
    :WORLDBALLSET
    Name=E01Snow
    SunAz=-60.0
    SunEl=25.0
    SunCol=255,255,255
    SunStr=0.4
    IblCol=255,255,255
    IblStr=0.6
    The format is pretty intuitive, and there's some notes at the top of the file itself. Feel free to change the parameters to suit yourself (sun colour/strength and IBL colour/strength are the ones you're most likely to want to change).
    If you have other latitude/longitude-mapped or angular-mapped environment images from other sources you can use them with the WorldBall. All you need to do is make sure that the images are in a mapped Poser runtime, and then add a new datablock
  • KeryaKerya Posts: 10,943
    Woooooow! Thank you!
  • DorseylandDorseyland Posts: 724
    Looks pretty cool on first glance in DS3, Cheap. Well, not FIRST glance, because the first time it crashed the program, but it worked fine the second time -- probably just getting to know one another.
    I expect this to be very useful. The scripting is way over my head, but delivers instant, easy results. Thanks a lot!
    Dorseyland: Hmmm... crashing DAZ Studio 3? That's not good! Are you using PC or MAC? Was it while running the script, while rendering, or while doing other stuff? I've had the occasional crash (with DAZ Studio 3 and 4) while developing this but never got to the bottom of it...
    gingercakes47/Kerya: Don't forget that I do like to know about problems (if you run into any)! Don't me afraid about bruising my ego... :cheese:
    P.S. The Simple DAZ Studio WorldBall got a very low one star rating at ShareCG from somebody else, so I guess there are some serious issues with it! Just on the off-chance that they're reading this thread It would be nice to know what the problem(s) was(were) - one piece of constructive criticism is often worth more than a hundred 'thank you's!
    Low star ratings at sharecg are often by somebody who doesn't know where to click.
    You can go to "my account" (below the login) and see who it was, by the way.
    I am very much behind my installations of things I want to install ... *insert very red face*
    I wouldn't fret about Worldball crashing my DS3 on a weakling PC, certainly not on the first try. What little RAM power I have complains bitterly about the size of my DAZ runtime. I really have to cut the runtime down to size -- or get a more powerful computer.
    Just launched Worldball again and did a string of renders with no problem whatsoever. Of the 2 below, the second one includes an overhead spot with raytraced shadow, trying to harden up the ground shadow. Doesn't work too good and spoils the IBL effect. So the ONLY "if only" I have about Worldball would be for more realistic shadows.
    I'm certainly not complaining. In fact, I'll head over to Sharecg right now and do something about that rating. Much appreciated!
    1005 x 733 - 106K
    1207 x 733 - 108K
    edited June 2013
    Prompted by Dorseyland's comment above: There's a fair bit of flexibility avaible with just the Sun and IBL - check out the attached DS4 renders . To get sharper shadows try adjusting the Shadow Softness for the WorldBall Sun:
    - select the 'WorldBall Sun' in the 'Scene' tab, go to the 'Parameters' tab, and you'll find it under the 'Shadow' section.
    You can also adjust the colour of the sun shadow, but NOT via the 'WorldBall Sun'! You need to select the 'WorldBall Ground DS3/4' in the 'Scene' tab, go to the 'Surfaces' tab, and you'll find it under the 'Shadow Catch' section (the ground has a simple ShaderMixer shadowcatcher material applied to it).
    If your figures look too dark/bright, or if the balance of Sun versus IBL seems wrong, or if you just want to fiddle with the lighting:
    - select the 'WorldBall Sun' in the 'Scene' tab, go to the 'Parameters' tab, 'Light' section and adjust Colour and/or Intensity
    - select the 'WorldBall IBL' in the 'Scene' tab, go to the 'Parameters' tab, 'WorldBall IBL' section and adjust Colour and/or Intensity
    The default settings for all environments in the WorldBallData.txt file are such that IBL Intensity + Sun Intensity = 100% but it's not a golden rule or anything. In fact I think the lighting looks too flat with the default settings (that's probably why ambient occlusion is used with most global illumination systems - the DS WorldBall hasn't got that)
    It's also worth doing two test renders every time you change, one from the sun side and one from the shaded side, just to double check the balance...
    Additional distant lights don't work too well in combination with the IBL/Sun unless they have a very low intensity - try fiddling with the Sun/IBL instead. However, pointlights and spotlights can work quite nicely.
    N.B. The WorldBall IBL does NOT use shadows. Although there's also a 'Shadow' section on its 'Parameters' tab, 'Shadow Type' should be left as 'None'. The only reason the 'Shadow' section appears (and for DS4 the only reason the empty 'Renderizer' and 'Shader Builder' sections appear on the 'Lights' tab) is that I couldn't work out how to prevent it!
    Also the WorldBall IBL does NOT have any facility for ambient occlusion. It's my first ever attempt at using ShaderBuilder, and it's basically just a dzPointLight with a bit of lateral thinking applied - see post #18 of my DS Diffuse IBL thread...
    1000 x 1000 - 189K
    Thanks Kerya, I know who it was, and I'm guessing it was an accidental rating. But I'm half-hoping it was a thoughtful bad rating...
    And as far as user installation is concerned this WorldBall has been my most problematic upload - it's still not resolved!
    edited June 2013
    Don't Forget The Additional Environment Sets
    There's already a few additional environment sets uploaded to ShareCG. Mountain Lake 01, Above The Clouds, and Below The Waves
    Each set is a full 360° azimuth / ±90° elevation environment in three formats:
    - A latitude/longitude mapped background image (4096x2048 JPG)
    - An angular mapped light probe image (1024x1024 JPG, flipped left-right from the background image) ...for Poser WorldBall IBL
    - A latitude/longitude mapped reflection image (1024x512 JPG, flipped left-right from the background image) ...for DAZ Studio WorldBall IBL
    Each set includes a text datablock (in the ReadMe) to add to your WorldBallData.txt file.
    Each set also includes the source file(s) used to create the original cube map. So far I've used Terragen Classic and Bryce 5.5...
    And if you're a DIY enthusiast you can Make Your Own Environment Maps And Light Probes using free software (Terragen Classic, HDRShop v1, and GIMP).
    250 x 250 - 28K
    250 x 250 - 26K
    250 x 250 - 29K
  • MelanieLMelanieL Posts: 7,091
    Thanks for these, they will be useful. I downloaded yesterday and tried them on my laptop and got NOTHING (that's still running DS4.0) but on my "real" DS machine (4.5) they're working great. (Note to self: Must get round to upgrading the laptop, but to 4.6 or wait for the next release???)
    edited June 2013
    Hmmm... the script reads the DS version, so it should automatically load the DS4 versions of the IBL/Ground on a DAZ Studio 4.0 system. So maybe DS4.0 doesn't like them? Maybe the DS3 versions would work? (No easy way for you to try that I'm afraid, unless you fancy editing the script!) I'll see if I can reinstall DS4.0 on my old machine and check a few things...
    Thanks for the feedback!
    Update: Okay, got DS 4.0.0.335 Standard 32-bit installed on the old machine, and I get the same symptoms as MelanieL - NOTHING! (well, the WorldBall gets loaded, but there's no background image, there's no Sun, no IBL, and no Ground). It's because the script crashed - it's in the logfile (Help > Troubleshooting > View Log File)...
    WARNING: Script Error: Line 1096 WARNING: ReferenceError: Cant find variable: DzFacetShape WARNING: Stack Trace: <anonymous>(&#41;@:1096 Error in script execution!
    Note to self: the solution's simple - DS4.0 needs to use the old DS3 DzPolyShape (the new DzFacetShape didn't replace it till DS4.5.x.x).
    Not sure how long it'll take to do the fix and test it, but I'll see if I can get it done by the weekend. No promises though...
    Okay, Pete, sorted out the shadows as per your instructions. (I knew all that -- I was just testing you.) (Okay, I admit it -- it never even occurred to me.)
    However, even keeping in mind your advice about keeping the view angle low, the shadows do have an odd angular look to them. Is there a better way of doing this?
    Mind you, I haven't used any depth of field on the camera here either, which you also recommended to soften any artifacts.
    1003 x 733 - 82K
    1003 x 733 - 97K
    Ah, sorry, I should have taken a look at the log file myself. Anyway, as I said it's about time I upgraded the laptop as 4.5 is so much better than 4.0 (and maybe 4.6 is even better still?) - I don't know how many people are still running 4.0, so maybe don't worry about it?
    Anyway thanks very much for these as I really like them (on my main machine)
    Just installed the WorldBall today and tried it out just to see if I could find it and get it to work. Got to admit, I'm pretty impressed. I'm uploading a pic but it's in my usual beta test mode so it's not a great picture, just to show you it works. When I've time I'll download the other three environments and post a real picture.
    Thanks very much for making this a free product.
    700 x 700 - 254K
    edited June 2013
    Looks like your shadow's getting cut off at the edge of the groundplane. Try increasing the WorldBall Ground scale to 200%. I initially had a very large groundplane but this caused quite a hit on render times, so I reduced the size of the groundplane to be just about big enough for the shadow of a human figure - too small for a helicopter in flight!
    I'd like to get it working for DS4.0 anyway, but I've run into a problem with the fix. I'll be asking some questions in a few other places to try and resolve it. In the meantime there's a lot of tidying up I can do in the script. So maybe not this weekend - perhaps a week or two?
    You're welcome!
    There’s loads of things I just got used to doing when I was testing the WorldBall, but forgot to mention in the ReadMe. I’ll be adding them to this thread as they hit me! So if there’s anything puzzling anybody about the WorldBall, keep posting your queries here…
    edited July 2013
    Problems Using The WorldBall On A MAC (FIXED - see post #33)
    19th June: N.B. I've just had feedback that the Poser WorldBall doesn't work on a MAC (not sure about PC) - I'm 99% certain I know what the problem is and I'm working on a fix...
    (For anybody whose interested, the PoserPython/DAZ scripts read the 'WorldBallData.txt' file line by line, stripping off any end-of-line characters (CR/LF). However, it appears that on a MAC a spurious character is left at the end of the line and this makes the script say the line is invalid.)
    I've also spotted another error in the DAZ Studio WorldBall readme (FIXED IN VERSION 2 UPLOAD)
    Added in red below ...
    IMPORTANT! SEE THE README FOR INSTALLATION DETAILS - THE SHADERBUILDER IBL MUST GO IN A VERY SPECIFIC LOCATION (BUT THERE'S A COUPLE OF ERRORS IN THE README TOO...
  • 3dOutlaw3dOutlaw Posts: 2,470
    edited June 2013
    If I turn off "cast shadows" on the ground plane, then I don't get any issues with using a Deep Shadow Map.
    ...but it looks good on first pass! (note: this is raytraced, not deep shadow)
    Added UberEnvironment2 at 35% Hi to the second pic...looks nice! :) Thanks for this.
    800 x 450 - 396K
    800 x 450 - 392K
    Post edited by 3dOutlaw on
    I'm quite liking the Below the Waves set too. Thought I was in over my head (so to speak) when I saw the scripting, but it synchs in quite easily.
    1003 x 733 - 159K
    edited June 2013
    I like it - I hadn't thought of using the UE with the WorldBall! That's by far the easiest way to get the AO working!
    The attached DS4 renders used the UE2 with light intensity set to 35% and UE2 light Diffuse Color using the 'E02LakeLL1024INV.jpg' image. The WorldBall IBL is switched off (eye icon closed in Scene tab)
    And thanks for that 'cast shadow' hint - obvious really, but I'd missed that!
    600 x 300 - 50K
    edited June 2013
    I'm having far too much fun creating different environment sets! There's another one already uploaded (Swimming Pool), another on the way (Northern Forest, DS render attached - the 'trees' don't pass a close inspection, but I liked the effect...), and I'm currently trying to perfect a jungle-type one...
    The script's nothing clever really - basically just a couple of DS3 material preset scripts and a DS3 lights preset script stuck together, with all the UI stuff removed, plus some code to read the datafile, provide a couple of user dialogues, and do the appropriate stuff.
    500 x 500 - 59K
  • RCTSpankyRCTSpanky Posts: 850
    One of the best additions for DS ever!!
  • edited December 1969
    I'm using the Poser version but I can't find a thread for it, so here is where I'll put in my two cents worth. This is a fabulous prop and free to boot! Pete, the Mac fix works and here is a quick render for you. I changed the light colors to more neutral shades and expanded the ground plane so the ship had a shadow. Thanks for all your help.
    600 x 467 - 93K
  • staticstatic Posts: 325
    edited June 2013
    Got a question for ya, cheapskate:
    I was perusing the WorldBall lineup and I noticed there is no #6. Did I miss a download or did the #6 not pan out? If there is one, I'd like to know where to get it. I love this environment setup. I've been looking for something better than cyclo and Mil Env. Thanks for this.
    BTW, using 4.6 and not a hitch.
    Post edited by static on
    edited July 2013
    :-) You're welcome!
    Thanks Teri. The Poser WorldBall MAC problem was a simple oversight on my part (the DAZ Studio version already strips both CR and LF from end-of-line, so the problem shouldn't occur there). Now I just have to remember to re-upload the fixed version! (btw - this thread is for both Poser and DAZ Studio versions)
    Don't forget that if you find a lighting setup (IBL/Sun colours and intensities) for any environment set that you like you can make it permanent by editing the relevant lines in the WorldBallData.txt file.
    #6 is the Mountain Lake 01 mentioned in post #15 - I just forgot to put the 'E06' in before releasing it!
