Adding to Cart…
hehe thanks Phil. I knew there was something I forgot to mention!
Congratulations!
Got it....thank you!
Silene
Dude, enter it! Looks great.
is that a giant rabbit in one of the promos?... eeeek!
ok... I'm having trouble loading the Carrara scene file.... it hangs on loading the scene
Instance tab shows the contents and they can be deleted but everything else is just hung up..
anyone else that has it have this problem.. I think I've come to the end of the track and crashed! Tried several times to load but same each time.
downloaded via DiM
Window 10 Pro 64
ok...
did some forensic testing..
The file loads ok in Carrara 8Pro but hangs in Carrara8.5Pro
so I loaded up in 8 ... deleted the info tip from the instance tab and resaved with a diff name so not to overwrite the file..
It now loads in Carrara 8.5Pro
also resaved from 8Pro with no adjustments and now loads into 8.5Pro...
The original file still hangs in 8.5Pro..... weird.....
End of the Tracks hung for me as well.
Running Carrara 8.5.1 Pro Build 19 (64 bit) on Windows 10 Pro. Downloaded manually and installed into my Carrara files.
I clicked on the End of the Tracks line in the Instances/Scene tab.
Next I clicked in the middle of the screen in my Document 3DView of End Of The Tracks.car and it then opened.
Nice scene, will have to play later tonight !!!!
Very odd, I have no explanation for that. The tip is just a helper object, so it's perfectly safe to delete, but even so, it was created in 8.5, and loads fine on both my machines (I don't even have C8.0)
yep... that worked for me as well...
now the question is why is it so?
Railmotor
Broken Bridge
just a couple of minor issues but a great set to break and pull apart modify and retexture..... great product @TangoAlpha
Stezza nice renders !!!!
One from me - "EEEEEEEK TRAIN"
lol, those are imaginative
Did I hear someone go "eeeek - giant rabbit" ?
Shades of the old, very very bad horror film "Night of the Lepus". https://www.warnerarchive.com/watch/night-of-the-lepus/742
In Louisiana, news of an invading horde of giant rabbits would have been met with great joy, and the invasion would have lasted about one day. Then the air would have been filled with the smell of cooking...smoked rabbit, BBQ rabbit, deep-fried rabbit, smothered rabbit with onions and peppers, rabbit sauce piquante.....
Thanks, TangoAlpha, this is a great set with so many possibilities!
I had not heard of that film, but will have to watch it now.
Thanks for posting the link to the website, looks interesting !!!
Out Now . . . MV Stella Engineering Deck.
https://www.daz3d.com/mv-stella-engineering-deck
360 View
Scotty, I need warp drive in 3 minutes or we are all dead!
Congratulations. Looks like a fantastic set.
I canno' give 'er no more capt'n... she'll blow!
Good luck with sales TA
DAZ-soon or REAL-soon ?
An awesome looking set and a great complement to your other Stella sets.
Some more pics:
The Stella is a small prospecting, mining and exploratory vessel, leased out by the Mars-Jupiter Mining Conglomerate to asteroid miners and other adventurers. The Engineering Deck is the lowest of its three decks, and holds engines, reactor, and life support equipment. Modular parts mean that props can easily be hidden or used in other sets. The hull wall is split into four parts for ease of camera positioning.
Looking great TA !!!!!
out now!
M3 making an appearance
Tis out! https://www.daz3d.com/mv-stella-engineering-deck
You might not have noticed, but the girl under the hatch in the first set of pics above, is wearing PhilW's new G8 hair (based on a Carrara hair...). Anyway, here's a portrait version;
Oh, and can anyone remind me how to add the sets used to a galley image?
Bought !!!!
Okay adding sets to Gallery image -
Click on the "Blue-man icon" then click on "My Gallery".
You will then go to the Galleries page section of your gallery.
If a new image drag your render picture to where it says "+Click or drop Picture(s)" then click on the image you want to edit.
Should take you into an edit window, in the box underneath "What content/software was used ?" enter the name of the product, if it is in the store it should pop up underneath, click on it, it should now be entered. Don't forget to save once you are happy with your list.
Cheers @Bynyip02
hmmmm I now have another shiney new TA item I wonderwhat I can do with it.
Maybe use it in the new challenge.
