Subsurface Shader Base
inspired_art_86a3f09735
Seeing as it has a DSON core installer, does this mean that this item is compatible with Poser, or am I reading it wrong?
These are a shader base for DAZ Studio only. Unfortunately DS shaders don't work in Poser, and vice versa.
Am using DS 4.6.0.15. I downloaded the SSSB using the DS installer but I don't see it listed as a plugin. The list of plugins is long, is it easy to overlook? Is it called "Subsurface Shader Base"? I have rebooted and restarted DS. I'd like to try it out but cannot find it.
It's not a plugin, it's a shader, so you'll find it the same way you would any other shader.
Content Library > Daz Studio format > My Library > Shaders > Age of Armor
It's not there. Age of Armor is not there.
Go into your DIM and check that the library location in it matches your library location for DS.
Cogwheel in the upper right > Installation tab
Check the paths in the lower box in there.
For DS.. Edit > Preferences > Content Library tab > Content Directory Manger @ the bottom > Expand both DS and Poser files and make sure they're set to where you want your library to be.
The path you set in DS must match that lower pane in the Installation tab in DIM.
Okay that did it. I created a new profile or folder location (whatever it's called) in the DIM which is the same as the one listed in DS. When I re-installed SSB, it showed up. Apparently I have not used the DIM before because there is no way it would have worked. Should work fine now though.
You're probably safe to remove the incorrect location from DIM and your PC if you have nothing else in it.
I'll use this, than i don't need to make a new topic, and i think, my problem is similar… at least at the beginning.
I can't see the shader, even after the third installation.
I'm using the DazStudio 4.6.1.17, i thought the shaders are included, but i couldn't find them. I downloaded them separately and installed with this install software… nothing. Ich downloaded it and sorted it manually… the same.
BUT: i can see the folder, Age of Armour/Subsurface/ but inside the folder ther's only the User Guide and ONE file, the '!Subsurface Base Shader' not the many different shaders like shown in the user manual.
What's my mistake?
Can anyone help me?
Its only 1 shader you can create different effects by altering the settings in the surfaces tab.
You can also buy some presets in the store here
http://www.daz3d.com/subsurface-toon-shaders
http://www.daz3d.com/subsurface-gummy-plastic-shaders
http://www.daz3d.com/subsurface-goop-shaders
AoA also has his metalised shader
http://www.daz3d.com/metalized-glass-shaders-for-daz-studio which I think might be referred to in the Guide which can be confusing.
