Lighting Tutorial by Laticis Imagery - Pretty good
13»
    Oh, no lighting change. I read no lighting, period. Whoops. My brain skipped right over the word "change". :p
  • Laticis ImageryLaticis Imagery Posts: 508
    I have trouble lighting characters inside rooms. Is the tutorial helpful for this?
    That is an excellent question...but unfortunately no it wont....that is challenge all on its own.
    Here is a render ( with post work though ) of Stonemasons Bot in a Box ( No open faces at all )
    http://laticis.deviantart.com/art/UberBot-The-HiRes-371406063
  • AJ2112AJ2112 Posts: 1,417
    edited August 2013
    Hello friends, Laticis tutorial is amazing !! Very simple, easy to understand instructions with illustrations, here's an image I created following the tutorial using basic female/Sabby Amber mats. No postwork. I also learned Uber 2,.
    Face has slightly bluish tint, I will correct as I continue to learn lighting,.
    Took me approx 30 - 45 min to complete the tutorial. At the moment, I create portrait renders cause my computer system is not powerful enough to render scenes :-S Took my comp 37 minutes to render this image. Uber2 sux the life out of my comp.
    I highly recommend tutorial for those that desire to learn portrait rendering. Definetly a solid foundation to work from.
    Happy rendering !
    650 x 487 - 133K
    Post edited by AJ2112 on
    Hi Awesomefb,
    Thank you very much for posting your result and for the great feedback about the tutorial...much appreciated.
    I hope it helps to improve your work.
    Cheers Laticis
    Happy rendering indeed :)
  • SorelSorel Posts: 1,434
    I'm so glad I found this. Funny enough when I finished the tutorial I realized I have a lot of light presets I can already setup like this with minor tweaking. Here is one image I did, rendered in about 4 hours. I left the specular a bit high but that's what I get for not doing a test render first. Other than that I am pleased with how it came out. Did some touch ups in PS6
    2000 x 2000 - 4M
    Hi Endrance :)
    Thanks for sharing, good work.
    The next step will be to develop the bond between surface materials and the lights.
    Cheers Laticis
  • KharmaKharma Posts: 3,214
    Haven't tried this tutorial yet...is the render time extremely long..sorel you said yours took 4 hours...is that unusually long or about right for lights?
