Duplicate formula found in loading G3 female
TraceSL
Just started to get Duplicate formula found error when loading any G3 female model, even the base figure. The figure loads after I hit okay and appears to be fine but wondering why this just started to happen and if there is a fix for the issue. G8 and G3 male have no issues.
Have my content on a secondary drive but has not had problems with that.
Error just started and have had no issues before today. Have uninstalled G3 and re-installed with no change.
Thank you for any help you can provide.
The issue appears to be Anain&Akasha/AAEyelashes/A&ALashes.dsf - I guess from a recently installed character. Does that sound familiar? if so try uninstaling and see if the issue goes away, if it does then bug report it (though it may not be a bug in that product but that the product is the second of two using identical names).
I do not have a character installed by that name.
Issue did start after installed Alexandra 8 Pro but that is a G8 character.
Searched my folders and found the Anain&Akasha/AAEyelashes/A&ALashes.dsf in Megah and Swimsuit for Genesis 3 and 8 female Have uninstalled the Megah character and the issue has disappeared.
Than you for pointing me to the correct seach path.
Since that's from the Daz store please report the issue to Techncial Support - though as I said, it may be a conflict with another product rather than an actual bug in this product.
Will do. Thanks again.
