Duplicate formula found in loading G3 female
Just started to get Duplicate formula found error when loading any G3 female model, even the base figure.  The figure loads after I hit okay and appears to be fine but wondering why this just started to happen and if there is a fix for the issue.  G8 and G3 male have no issues.
Have my content on a secondary drive but has not had problems with that.
Error just started and have had no issues before today.  Have uninstalled G3 and re-installed with no change.
Thank you for any help you can provide.
txt
txt
log20180214.txt
1M
  • The issue appears to be Anain&Akasha/AAEyelashes/A&ALashes.dsf - I guess from a recently installed character. Does that sound familiar? if so try uninstaling and see if the issue goes away, if it does then bug report it (though it may not be a bug in that product but that the product is the second of two using identical names).
  • TraceSLTraceSL Posts: 546
    I do not have a character installed by that name.
    Issue did start after installed Alexandra 8 Pro but that is a G8 character.
    Searched my folders and found the Anain&Akasha/AAEyelashes/A&ALashes.dsf in Megah and Swimsuit for Genesis 3 and 8 female   Have uninstalled the Megah character and the issue has disappeared.
    ​Than you for pointing me to the correct seach path.
  • Since that's from the Daz store please report the issue to Techncial Support - though as I said, it may be a conflict with another product rather than an actual bug in this product.
    Will do.  Thanks again.
