Released-LIE Tattoo Presets 2 (Commercial)
DarwinsMishapDarwinsMishap Posts: 4,087
edited February 2018 in Daz PA Commercial Products
Good evening and all that.
This package uses the LIE system to add tattoo overlays (diffuse, translucency and bump overlays) to your Genesis 3 and Genesis 8 Male and Female figures. Along with some of the tattoos from my character sets I have included a few new tattoos to the pack.
This set is tested with the Genesis 3 UV's, and as the promos show it can work on the Genesis main figures as well, but be aware there are two or three tattoos that may have seam issues if used on another UV set.  Since the Genesis 8 and the Genesis 8 main figures use the same UV set, this will not be an issue on the Genesis 8 version.
There are two Material folders: The Tattoos 2 is a system built for the Genesis main figures, both Genesis 3 and Gensis 8, and the N.G.S. Anagenessis folder files should be used with that shader system, or any other shader system that has a texture map in the Gloss Specular slot in the Parameters/Surfaces.  To figure out which to use, it is easiest to load your character into Studio, go to Parameters/Surfaces, unfold the main figure in the left side of the Parameters/Surfaces tab until you see the individual material zones.  Select the "Arm" and in the right side of that tab scroll down to see if there is a texture map assigned to the Gloss Specular slot.  If so, the N.G.S system is the way to go!  If not, then the Tattoos 2 files are what I would suggest should be used.
Great thing about the LIE is that it doesn't matter if the render engine is Iray or 3Delight, it's all in the skin, not the engine! Base character skins have not be changed other than to add the LIE Tattoo Presets to each.
There will be a LIE Tattoo Presets 2 set for Genesis 3 and 8 Female, a LIE Tattoo Presets 2 for Genesis 3 and 8 Male, and a LIE Tattoo Presets 2 Bundle with both sets to choose from.
https://www.daz3d.com/lie-tattoo-presets-2-bundle-for-genesis-3-and-8
https://www.daz3d.com/lie-tattoo-presets-2-for-genesis-3-and-8-male
https://www.daz3d.com/lie-tattoo-presets-2-for-genesis-3-and-8-female
Post edited by DarwinsMishap on
