Released-LIE Tattoo Presets 2 (Commercial)
Good evening and all that.
This package uses the LIE system to add tattoo overlays (diffuse, translucency and bump overlays) to your Genesis 3 and Genesis 8 Male and Female figures. Along with some of the tattoos from my character sets I have included a few new tattoos to the pack.
This set is tested with the Genesis 3 UV's, and as the promos show it can work on the Genesis main figures as well, but be aware there are two or three tattoos that may have seam issues if used on another UV set. Since the Genesis 8 and the Genesis 8 main figures use the same UV set, this will not be an issue on the Genesis 8 version.
There are two Material folders: The Tattoos 2 is a system built for the Genesis main figures, both Genesis 3 and Gensis 8, and the N.G.S. Anagenessis folder files should be used with that shader system, or any other shader system that has a texture map in the Gloss Specular slot in the Parameters/Surfaces. To figure out which to use, it is easiest to load your character into Studio, go to Parameters/Surfaces, unfold the main figure in the left side of the Parameters/Surfaces tab until you see the individual material zones. Select the "Arm" and in the right side of that tab scroll down to see if there is a texture map assigned to the Gloss Specular slot. If so, the N.G.S system is the way to go! If not, then the Tattoos 2 files are what I would suggest should be used.
Great thing about the LIE is that it doesn't matter if the render engine is Iray or 3Delight, it's all in the skin, not the engine! Base character skins have not be changed other than to add the LIE Tattoo Presets to each.
There will be a LIE Tattoo Presets 2 set for Genesis 3 and 8 Female, a LIE Tattoo Presets 2 for Genesis 3 and 8 Male, and a LIE Tattoo Presets 2 Bundle with both sets to choose from.
https://www.daz3d.com/lie-tattoo-presets-2-bundle-for-genesis-3-and-8
https://www.daz3d.com/lie-tattoo-presets-2-for-genesis-3-and-8-male
https://www.daz3d.com/lie-tattoo-presets-2-for-genesis-3-and-8-female
This is awesome!
Wonderful!
That was Dimension-Z
Thanks, Doc. I'll see if Daz can update that. My bad. lol
Exactly what I wanted. If it is not released tomorrow, then I'll be able to get it before it goes off introductory sale.
I sent in a fix for the derp moment on the mention. :) And thank you, Xyer0!
Not yet, Alliekatblue-Soon!
Oh good, I have this thread bookmarked now
They're here!
Some really spectacular tattoos in these sets!
Is there any redundancy between this and your previous tattoo set?
Thanks, Sonja!
And, no Xyer0- there are different tattoos snagged from several characters that have been released that were not in the previous set, as well as some new ones that aren't on anything I've created. I've made these sets for people that would like to use the tattoos I've done previously on other characters and decided that a few new ones per set would be the right way to go as well.
Great! I can get them both!
