GENERAL FREEBIE REQUESTS Part 2
19091939596100
  • kimhkimh Posts: 398
    edited February 2018
    MDO2010 said:
    @kimh - I had some time to get started on this today. Still a little work to do on the Brigid's Cross. It took me forever watching Youtube videos to figure out how it was actually put together! I kept loosing track of which side I had just done and having to start over. I played around a little with the corn dolly just to figure out how to approach it and I think I have a method that will work using a cloth sim. laugh
    I should have these both for you next weekend; I only get a few hours on the weekend to play with my 3D hobby and since we missed the holiday for this year, I figure there's no rush. wink
    Here's where the Brigid's Cross is so far:
    (Iray render in Substance Painter)
    I still want to work on the twists and bends a little and add some trailing ribbons to the wrappings holding the ends together.
    You are right...there is no rush. But the Brigid's cross looks wonderful. I actually got to make my very first Brigid's cross Friday night so I know exactly what you mean by forgetting on which side you started...lol
    Post edited by kimh on
  • EightiesIsEnoughEightiesIsEnough Posts: 1,252
    I see the hair net for cafeteria workers is posted.  But while on the topic about high schools, I am wondering if there are any free props for the following:
    • Principal's office
    • Chemistry lab
    • Swinging doors
    • School hallway
    • Cafeteria food
    I did purchase a school gym, classroom, and cafeteria scenes already.
    Post edited by EightiesIsEnough on
  • Does anyone know if a free Zulu-type shield is available anywhere?
  • Charlie JudgeCharlie Judge Posts: 13,399
    A free Manza shield is included in this free set: http://www.vanishingpoint.biz/freeitemdetail.asp?FreeItemID=281
    With retexturing this free shield might work: http://www.sharecg.com/v/58121/browse/11/Poser/Sword-Shield
    Post edited by Charlie Judge on
  • In addition to my request in my last post, is there a free apron I can download for a cafeteria worker V4 figure?
  • fleetppfleetpp Posts: 199
    https://www.renderosity.com/mod/freestuff/apron-for-v4/45024
  • I am looking for some v4 overalls or any clothing with paint on or to do with decorating as long as they are for v4...Thank you.
  • I'm trying to find a peacoat and turtleneck for either G2M or G3M
    I'm trying for this kind of look:
    Wopuld this winter jacket work? https://www.wilmapsdigitalcreations.co.uk/view_product.php?id=264
    Thank you, but no. I tried that one already, it doesn't open enough at the front.
    Well, this opens more in front, but unfortunately is not free: https://www.daz3d.com/h-c-coat-outfit-a-for-genesis-3-male-s
  • DollyGirlDollyGirl Posts: 2,709
    http://www.optitex-dynamiccloth.com/FreebieDownload06.php
  • beachlegsbeachlegs Posts: 526
    Thank you my friend I will keep this one in mind a little too baggy but might work :)
  • Help finding the 40k Adepta Sororitas stuff that Obiwan translated to v4 before 3d heritics went down.
    That is actually MUCH more like what I'm looking for.
    Guess I'll just have to wait until I get paid lol
    Thank you!!
    If you have the dynamic clothing control plugin you can make it shrink a bit - a better bet either way might be to do an animated drape with V4 scaling larger as well as getting into pose to the last frame.  Then export the resulting clothes as an obj, reimport, copy surfaces back over, parent to V4 and scale back down.
    Thank you I have managed to find something now and changed the textures to fit what I was doing...I really appreciate your help and will keep this in mind as I am sure I will need it in the future :)
  • kyoto kidkyoto kid Posts: 42,117
    ...still looking for a free model of one of these:
    Not free but only $3: https://www.turbosquid.com/3d-models/3d-greek-shopping/723422 Comes in obj format.
    ...yeah, seen that one however only need it for one particular scene.
    How detailed do you need it?  Does it have to fold up like in the picture or would a more static model do?  It's simple enough to model the static one, relatively simple to uv-map, then texturing could just be metal/rubber-shaders if you don't need too much detail.  A nice ray-traced reflection would work for the metal if you had a 360 environment.
    (I ask because I'm at work and free for a bit so I'm modelling one in Blender for practice.)
    Do the wheels need to move?  (doable but would need to wait until I can get time with DS at home).
    ...doesn't have to fold up or the wheels need to rotate. Need it for a single frame scene.
  • Silent WinterSilent Winter Posts: 3,913
    How close to the camera?  See image for progress so far on the modelling (no textures applied and the blender render doesn't have anything in scene to reflect even if I added reflection to materials).  It doesn't have the fine detail of the turbosquid one (I'd need a lot more time for that, and I'm too busy), but if it's close to what you need, I'll finish it up.
    At the moment, the tires are just a material setting on the wheels (so close up it wouldn't look good) but if needed I could make them look more separate.  There's also no 'weld' at the joins and the frame cylinders just pass through each other (it's 8,800 polys as it is).
    It's also at the wrong scale as I'm not at home to import G3/etc for testing.  But that's just a scale dial away.
    960 x 540 - 32K
    Post edited by Silent Winter on
    ...just need it looking good for 3DL.
    Sure (don't worry - I know you work in 3DL ;) ), but that's more down to the shaders used.  If you've got a metal / rubber shader for 3DL (easy enough to set up actually - but I can't provide reflection maps, so you'd need to reuse one from an existing set, or use ray-traced reflections), the mats will look fine.  But how close-up?  Is the model detailed enough as is?  Or do you need more?
    Based on the image I provided, what needs changing?  (I'm not at home right now, so I can't take it into DS and try doing the shaders there - I should have time tomorrow if you can wait (though I'm supposed to be working on textures for my kung fu school set).
    See new image below for limitations on current mesh for close-ups.
    960 x 540 - 51K
    ..actually in the mid background.  Most are actually not very shiny, so don't need a reflection map.. I have 3DL metal shaders I can apply to the basket and wheel spokes so if the tyres are a different material zone that is all I need.
    Post edited by kyoto kid on
    Okay, how about this:  Here's the .obj file (zipped because we can't upload .obj file type to the forum) - try importing it into DS, scale it to fit your character/scene, and set some materials to the metal / rubber mat zones (a basic non-glossy plastic would probably do for the 'rubber' if it's not close up.
    Give it a render and let me know if you need anything changing :)
    Edit: I always forget the readme:
    This is licensed for commercial and non-commercial renders the same as any item bought at Daz.
    zip
    zip
    Shopping Cart.zip
    279K
    ...thank you. I'll post the rendered scene.
    Glad to help - looking forward to it :)
    ...it will be in the scene I have currently been working on.
