The Ultimate Super-Hero Freebie List!
1121315171821
  • tkdroberttkdrobert Posts: 3,637
    edited January 2018
    I posted this in the wrong thread.
    Post edited by tkdrobert on
    I think you should put those in the DAZ Section.  Thanks you for the costumes.
    Actually, I tried to put them in the DAZ Section. But when I started uploading, there was a glitch, and it switched over to 3D Models. It happens most of the time I try and upload something. Still, glad you like the costumes. I have more on the way.
    That explains a lot LOL!  Looking forward to your new items.
  • magicjavamagicjava Posts: 152
    edited January 2018
    Hi guys! I've just uploaded some Kibry Krackle obj files to my Google drive. They're free to use, with no liscensing restrictions. I hereby place them in the public domain, which means you can do whatever you want with them.
    Here's a sample image using the Krackle.
    Post edited by magicjava on
    edited January 2018
    Here's another picture done in DAZ Studio using only models available in my Kirby Krackle download. No postwork (except to add word balloons).
    Great idea! But if you don't mind me giving advice, you could just as easily set up a ShareCG account make your Kirby Krackle available over there.
  • Just wrapped up a Killer Frost costume for G2F and G3F, as well as Iray textures for both versions. The costume is based on the version of Killer Frost from DC Universe Online.
  • SkelchSkelch Posts: 276
    Thank you my daughter has to create comic book for a class in college and she will be thrilled to see this is now availible.
  • Recently completed a new Juggernaut costume. It's rigged for Genesis 2 Male(s) and Genesis 3 Male(s).
  • Geminii23Geminii23 Posts: 1,328
    Anyone know where I might be able to find a chest harness for the classic blue and yellow cyclops outfit?  I have seen a few renders including some done in DAZ, but have been unsuccessful in finding anything out there that might work.
    Thanks
  • SixDsSixDs Posts: 2,384
    Well it might take a little kitbashing and modding, but you could look at Gary Childress' various suspenders here:
    http://www.sharecg.com/pf/full_uploads.php?pf_user_name=garychildress
    Great Juggernaught costume OrionPax09. I downloaded it and tried to bring it into both Daz Studio and also Carrara and get an error message "...OpJggr_Helmet.dsf" could not be found. I get the same error message when I try to load all your costumes. Any idea what's going on?
    Thanks,
    Brian
    743 x 120 - 28K
    452 x 303 - 27K
    Thanks,
    Brian
    Really? I don't know what the problem could be. I mean, I have sent my costumes out to be tested in order to avoid problems like this happening, and this has never been reported. I even doublechecked the data files for that particular costume, and found the file you're missing without any problem. And when I did a test download of the ZIP files and extracted everything, I was able to find the mentioned file without any difficulty. And everything is working fine on my computer.
    And you say this is a recurring problem with all of my costumes?
    1059 x 668 - 57K
    Thanks,
    Brian
    Believe me, if I knew how to change categories after this happens back to DAZ, then I'd gladly do so. But I have no idea. As far as I can, categories are locked after submission.
    Any suggestions?
  • BrianP21361BrianP21361 Posts: 816
    edited February 2018
    Thanks,
    Brian
    Yes. I've had the same issue with the two Stunner costumes, Namorita and the Silver Surfer Board. I've seen this issue before and sometimes I can find a work around. No luck with Juggernaught so far. I've double checked and I have all the files and they are in the folders you showed. It just can't find them when I try to load them. I'm not well versed with this, but it might have something to do with relative paths verses absolute. What's the top level folder that I should put your products in?
    Post edited by BrianP21361 on
    Thanks,
    Brian
    After going into the Content folder, you just move all of the folders into My Library.
  • After going into the Content folder, you just move all of the folders into My Library.
    I tried putting everything into My Library and i got the same error. My folder structure is attached. do you see anything unusual with it?
    1066 x 1364 - 527K
    Um...when you say, you tried putting "everything" into My Library...you didn't, by any chance, also put the Content Folder in as well, did you?
  • Well, yes. i created a new folder called My Library and put everything in it. I manually added My Library in Studio. I've attached another screen shot. am I doing something wrong?
    812 x 715 - 265K
    I believe that I just found the problem. You see, because you added the Content folder into My Library, the resulting folder heirarchy becomes Content/data/OrionPax09/Juggernaut Cosplay for G3M/OPJggr_Helmet/OPJggr_Helmet.dsf. If I'm right, then the problem is that you created an extra level in the layer heirarchy, throwing the rest of it off.
  • I believe that I just found the problem. You see, because you added the Content folder into My Library, the resulting folder heirarchy becomes Content/data/OrionPax09/Juggernaut Cosplay for G3M/OPJggr_Helmet/OPJggr_Helmet.dsf. If I'm right, then the problem is that you created an extra level in the layer heirarchy, throwing the rest of it off.
    That was it! I added the runtime at the Content level and now I can import all of your costumes. Thanks so much for all your help!!!
    Glad to hear everything worked out. When you get around to using my stuff, I wouldn't mind seeing what you come up with.
  • OrionPax09,
    This is an amazing costume.Thanks very much for sharing. I've attached a few WIPs so you can see how I'm using it. I'm not sure which body I like best. Juggernaught is usually drawn very big, but he seems too bulky in the last two images. Rendered in Carrara.
    1200 x 900 - 252K
    1200 x 900 - 296K
    1200 x 900 - 282K
    1200 x 900 - 321K
  • OrionPax09OrionPax09 Posts: 419
    OrionPax09,
    I'm glad you like it. Just so you and everyone else knows, I've recently completed Iray presets for this costume. Check out Juggernaut Cosplay - 3Delight and Iray Presets.
    Post edited by OrionPax09 on
  • OrionPax09,
  • Max_theHitmanMax_theHitman Posts: 66
    Super post!
    Thank you so much!
    Post edited by Max_theHitman on
    OrionPax09,
    Wow!  This looks awesome.  Instant download!   Thanks
