Adding to Cart…
Excellent
If you want to save the draped clothing/poses result you get from dForce it is just a matter of hiding everything else in the scene, export the garment as obj. (make sure is at base resolution). With the posed figure still in the scene and unhidden, remove simulation data from the garment then use Morph Loader Pro to bring your appropriately named obj. in as a morph (use reverse deformations). Save your morph and voila! it will be there anytime you want to use it again without having to run a simulation again.
In my pre-dForce clothing sets I named the morphs to match the poses they were draped on, takes the guesswork out of trying to figure out which morph goes with which pose. :)
I agree, with all the subtopics people have posted it's difficult to search through and find what might work. I'd rather have some things not work for me and have to search for the 'why' in the thread, than to have to read each and every post.
Storm wind wanderer worked beautifully for me.https://www.daz3d.com/stormwind-capes-for-v4 In fact when set air resistance to 1 it was so awesome that I could have stopped the render at a lot of places to render it. I've included one render and a few screen captures to show how it could have been stopped to capture movement. I did not try to refit it to a genesis (1,2,3 or 8) to see if that affected it.
Arissa and sciwizard both exploded.
Could someone give me a link to instructions on creating the wind. I could not find it when I used search in here or on google.
Thanks, good info.
Just beautiful. And also fun that while I was trying the desert wanderer cape you were also posting it. :)
If you have the dforce starter essentials pack which should be in your downloads, there is a sample scene in there with the wind function in use.
Thanks. I’ll look into it.
@frenikyn I also explain how to set up the wind node here
Thank you for displaying your settings. This is very helpful.
I found this forum thread yesterday and read each post all the way through it. dForce has fascinated me since it came out, and I learned so much yesterday. I tried to put my new found knowledge into practice this morning, and here's the results.
I used
CandyDress from - DAZ
Glamor Outfit for Gen 3 from - Daz
Day in Bed from - Daz
HotDream Panties from - Renderosity
Sporty Ponytail hair from - Daz
PH Candy Hair from - Daz
Just a simple primitive plane was used for the sheet. (Love how it forms around the girls in bed)
None of these items are certified as dForce, yet they worked.
(Also numerous shaders were used)
Adding a push modifier and adjusting it to taste to some of the items, like the sheet and dress on the bed, thicken them up a bit so they don't look like they are painted on.
Lastly, anyone seriously interested in dForce should consider these new products in Daz Studio:
Cloth dForce Presets
Hair dForce Presets
Even on sale at $17.95 a pop, it's still a strong hit, but they work well and help a lot with some problems I'd been experiencing before.
Hope this can help others, as so many of you helped me yesterday.
Andy
I don't even see anywhere where self-collision is specified.
I am trying to kep clothes from exploding in simulation and this seems to be happening a lot.
It's on the Surfaces parameter tab. Towards the bottom of the dforce settings section
Oh, fantastic DaWaterRat! There it is and a lot of other phsical properties that will be helpful in simulation! I feel so much smarter now that I know that!
^__^
Mada! Love the surface of that fabric. Kind of glassy, waxy, silk...dunno what to call it.
:) I added shaders from this set to the textures - highly recommended : https://www.daz3d.com/subsurface-workshop-sss-shaders-for-iray
Kaleya's XOXO for G8F works great right out of the box.
If you need a dforce friendly version of Regency type fashions, check out Esha's Dynamic Empire Dress. Originally a poser dynamic for V4, it will work with DForce as long as you pose the character as close to default V4 pose as you can get, and then run an animated drape. The main downside is that it loads with a default semitransparent texture set (period appropriate, especially on the French side of the Channel, but not necessarily desirable) which will not look right if you simply yank the transmap out of the opacity channel, and the poser material presets do not seem to work in DS, so you have to go to the surfaces tab and manually browse to the alternate textures to apply them. The belt area (just below the chest, where this style of dress is supposed to be gathered) is a separate material zone, so it would be easy to dial the Dforce constrain/expand ratio to 99% and make the silhouette slightly more authentic than I have in my picture.
Because it's V4 and a RDNA buyout, it seems to go on super-sale fairly often, I picked it up for a couple of dollars during the flash sale on Esha's store some weeks back. I wouldn't say it's worth more than that, but if you want a drape-able version of those very elegant and distinctive dresses from the Directoire/Regency/etc era, it's worth checking out. Comes with a prop reticule and a pair of shoes that don't autofit to other figures well, but in the picture below G3F is wearing a day bonnet and reticule from the Regency G2F sets and the shoes from Victoria Iven.
I was very pleased to find that using dforce makes all the female centaur clothing “blankets” workon humans as skirts with use of swayback parameters adjustment.
I tried an older dress model for Aiko 3 (yea, the original) called DClassyA3 It's a pretty dress, classic design but it's obviously not welded properly and the trim just explodes and not sure if this can be fixed from within DAZ Studio? When I tried to weld it in ZBrush I get a notice that it's no longer the same mesh, duh. I'm just playing, nothing needed but just wondering if this is something that DS can do or am I SOL?
In your shoes, I would probably just hide the trim (white bits at hem and sleeves, maybe collar?) using the opacity dial in the Surfaces tab, and turn DForce simulation off on them (also in the surfaces tab). I think dress would look fine without it.
I have to say that I'm amazed while scanning through the posts in this thread. I've had several attempts at getting dForce to work on non-dForce items and, in almost every instance, I end up with an explosion. I've spent hours seraching the forum for advice which seems to boil down to: garment must be a one-piece mesh; no buttons, laces, straps, strings or zippers; don't try "difficult" poses, make sure mesh doesn't intersect with anything (though I'm not sure how to make sure of that). In short, dForce will probably not work if the clothing was not designed for dForce (and even if it was, it will still explode quite often). Which is why I'm amazed at this thread.
If anyone has a definitive method of avoiding explosions, please share because I can't find one.
Try turning self collision to "off" (it's on by default). In my experience, that usually stops things from exploding.
Yeah, but sorry - that's usually the first thing I do. I see that said in almost all of the advice yet mine explode. I must be missing something because this thread is proof that some people are getting results.
BTW - I've had a look at your thread on using the simulation presets - very impressive and comprehensive. A great help to those who have that product. I don't but it is on my wishlist. I'll probably wait for a couple of updates to dForce to see if they can do something about the explosions, however.
Next thing to I'd check would intersecting (that's the second common cause of explosions in my experience). Meaning, checking that the hands/fingers aren't touching the garment. So poses with hands on hips might create explosions if part of the fingers are going through the clothing.
Another thing you can try is layering the collisions (doesn't always work, though). Which means if you have a layered dress, then after applying the dforce modifier, you'll want to go to "collision layers" and set the one nearest the body to "1", then if there's a layer on top set that to "2" and so on.
The product is very useful but I wasn't using it to it's potential because I didn't know the difference between each preset (which is where the need of the guide kicked in). Now I'm actually getting some good use out of it. I would def. recommend it. I can assure you the preset will help you avoid explosions. Things that exploded on me using the default dforce settings, don't explode when using these presets.
Thanks again. I do try to avoid hands touching anything (I usually move the arms wide of the body - I can always move them back again later which is something that wasn't possible with OptiTex). I didn't understand the collision layer setting so your tip might make a difference although I can't think of a layered garment that I have tried.
Yes, I do want to get those presets but I'm always on a tight budget which is why they are wishlisted. Maybe they will be on sale one day.
